I am performing a 1.8t conversion on my mk2 golf syncro. I am using a corrado rear aluminium engine mount bracket pn:357 199 354 My question is will i need to change my front engine mount bracket also? If so does anyone have the make and model/pn that i need? These are the vibratechnic mounts that I have bought: Engine Mount Rear (vag 875 - road) Gearbox mount (vag 970m - road) Engine Mount Front (vag 800m - mk2 VR6)
Its a mk2 golf syncro(ive edited above post now, thanks), i am using a rallye gearbox (o2c box from a passat syncro). p.s. your car is going to be amazing when finished! Love it!
Ahh, OK. Use all the engine/gearbox brackets from the Passat. They should allow you to drop it straight in to the Mk2 using the VibraTechnic mounts. That's what I did with my Mk2 when I S3'd it, albeit with parts from a FWD Passat. Good luck! Edit: It was finished and I loved it. Then a lorry hit it while it was parked. Need it back soon, cos my Mk3 8v GTi is doing my nut in. LOL!
