vr6 top mounts on mk2 ..whats needed
Discussion in 'Chassis' started by pigbladder, Jun 6, 2004.
  1. pigbladder Forum Addict
    cambridge , uk
    okay i hear vr6 are a good upgrade for a mk2 golf....can anyone tell me for sure whats needed??
    please only answer if you know for sure, not what you heard down the pub etc
    any part numbers for ecp /gsf would be good too
  2. smithy Forum Member
    Scotland
    I got a Febi VR6 top mount kit from GSF, part no 45737K and they seem good quality. They use a seperate bearing (included). Havent fitted them yet but was informed by PhatVR6 that they work fine. They certainly look a lot stronger anyway.
  3. steve r
    steve r Forum Member
    got this set up on my g60 with normal shock/springs and the track car with coilovers,
    you need the rubber bush and bearing,special nut to secure them onto the shock, and the top plate and nut to go on top and hold the leg to the car, if fitting with mormal shock/springs you also need the mk3 spring top plate,
  4. pigbladder Forum Addict
    cambridge , uk
    so the mount n bearing from gsf and the rest from vag?
    so the mk2 nuts wont fit?
  5. steve r
    bought all my stuff from vag as i've had problems with G&S febi top mounts in the past.
    the mk3 setup uses a special shaped nut to hold the bearing onto the shock so you def' need that, you might get away with the mk2 nuts for the very top nut but i just ordered all new stuff, its not much for a new nut.
    just look on etka at the dealer and order everything above the spring.
    if your using the spring plate for normal shocks/springs i think theres a little play between it and the shock but once tightenede down its fine.
  6. steve r
    spring plate:357 412 341a
    bearing:1J0 412 249
    special nut: 1H0 412 365a
    rubber top mount:357 412 331a
    top plate: 357 412 319b
    topnut:&nbsp ;n 903 536 03
    Edited by: steve r
  7. pigbladder Forum Addict
    cambridge , uk
    any idea what you paid roughly??
    and...does it affect the ride height at all
    thank for the info
  8. steve r
    can't find the receipt, but i think it was around 40-50,
    didn't seem to affect the ride height.
