Water Trick
Discussion in '8-valve' started by nickh89GTi, Nov 10, 2008.
  1. nickh89GTi Forum Member
    Exmouth
    Hi Guys
    I am looking to try TSC's engine steam cleaning trick on my GTi but i cannot find the thread with it in. Does anyone have any idea where it is or got the link to the thread?
    since its a GTI you need to pop off a vacuum hose to the throttle body, and dip this in a pint of water. hold revs up and it should suck it all up eventually!
  3. nickh89GTi Forum Member
    Exmouth
    OK sounds simple enough. Does it matter which vac hose i do it through on the throttle body? Does it make any difference to the running of the engine? Thought it may be a good idea to do at as its been running badly as you know from last thread :lol:.
    Will much water get down into the oil?
    :thumbup:
    I used the one that connects to the airbox :)
    water shouldnt get into the oil it should get vapourised, if any does get past a good long run will burn it off.
  5. pigbladder Forum Addict
    cambridge , uk
    should clean it out nicley
    just dont let it sup the pint real fast...make it take sips instead
    some of the water will get in the oil , so best do it before a oil change
  6. nickh89GTi Forum Member
    Exmouth
    Sorry if this sounds a bit stupid but is the amount it sucks up controlled by me giving it a rev every now and again or is it just what it sucks up itself?
    Cheers Chaps
  7. Riley
    Riley Forum Addict
    Burnley/Lancs
    Id hold the rpm at 2k or sommet, the rpm will dip when you do it so if its ticking over it will probably stall.
    Neil.
  8. rubjonny
    harder you rev, harder it sucks :lol:
    it may stall if you fdont hold revs up, so if it starts to bog give it more revs
  9. pigbladder Forum Addict
    cambridge , uk
    you can dunk the pick up pipe in and out of the water so it take it in slowly
  10. paultownsend Forum Member
    what does this actually do? clean up deposits on the valves?
  11. nickh89GTi Forum Member
    Exmouth
    Think its cleans up any carbon build up in the bores and on the valves.
  12. pigbladder Forum Addict
    cambridge , uk
    yeah it steam cleans the chambers
  13. paultownsend Forum Member
    can flash cooling like this not damage things?
  14. Dubnutter Forum Member
    Salisbury
    Correct me if im wrong, but water cant be compressed, therefore if the engine takes in too much water without it evaporating or turning to mist, it will throw bits of conrod and piston etc all over the place.
    The steam cleaning theory works fine, and many people do it, but to be honest, id use a mister sprayer, like the one you use to water plants or clean windows etc, and put a tiny bit of acohol in with it.
    The reason for this, is that the tiny droplets are very small and the engine can handle this amount of water because it turns to steam well before tdc.
    And the alcohol just helps with the burn and to help burn up and spit out all the crap.
  15. rubjonny
    you need to put a lot of water in an engine to hydro lock it, if you keep the revs up and only put in a slow tricle of water theres no danger of it happening.
  16. Dubnutter Forum Member
    Salisbury
    i stand corrected :)
  17. rubjonny
    well not corrected really, everything you said is correct :thumbup: If you dumped a jug right down the inlet it wont like it, tho with a GTI its very hard to do that. Carby has more risk of this so just keep revs up and only pour it in slowly :)
    Good tip about the alcohol too, can only help. Maybe get a bottle of cheap nasty supermarket vodka, prob best use for it :lol:
  18. TheSecondComing Forum Addict
    Think about a 1.8 litre engine revving at about 3000 rpm, and the amount of water it would take to hydrolock it... loads! I don't even take the vacuum pipe out of the water, just keep the revs up with the throttle until it's drunk it all.
  19. Blue MK2 Forum Member
    This sounds well dodgy. :thumbup:
    Does it actualy work? Has it been proven? Anyone opened up their engine to find out?
    This the same as Sea Foam that alot of yanks use?
    Why water and not something like gunk?
    Tell a newby:)
  20. TheSecondComing Forum Addict
    It's been used since about the 1940s... ever seen the inside of an engine that's blown a head gasket and been drinking water? Clean as a whistle...
