Where can I get a M8 sleeve nut (female bolt) like this (update)
Discussion in 'Miscellaneous Technical Queries' started by A.N. Other, Jun 17, 2008.
    I suspect something like this will be on a VW somewhere, to save me a trip down the machine shop:
    There's an M6 version on a MK1 Golf GTI cambelt cover IIRC, with an allen head on it, and a really wide washer head, so I'm thinking one of the VAG mechanics on here will probably know where to get some, and I can then just walk into a dealer and order one. Would be much easier.
    TIA :)
  2. mk1. Forum Junkie
    pics not working chris,think I know what youre on about and might have something at work along those lines that we use on hydraulic pipe clamps,will need to check on the thread.
    It's that damned photobucket barring software that people are starting to use - it blocks everything.
  4. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    found part number/ pic for m6 version, can't think of anything with same bolt on
    is it std vag application?? or just a usful thing to get a job done, had look though std hardware, the cam belt nut not listed, special application?
    It's non-standard, so I'm just looking out for one, since the blighter must exist somewhere (!) and there's a decent chance of one on a VW.
  6. vrbanana Forum Junkie
    Sunny Sheffield
    I’ve found a bolt from a VW/Audi that could be made into what you want, it’s the same design as the VW cam belt cover bolt buy with no hole and thread, could easily be drilled and tapped out with an M8 thread. Head diameter 26mm, shank diameter 18mm, shank length 38mm but could be shortened before drilling and tapping, hex socket is for 8mm allen key.
    It’s from the cam belt tension on 1.8t’s[:-B] [:-B] [:-B] :lol:
    Can’t buy them separately, they come with the tensioner on 1.8t’s etc, I have one fro and old tensioner if you need it
    Please Daz - any chance of bringing it to Inters?
  8. PhatVR6 Forum Junkie
    most bolts on vag cars are made by ABUS, see if they sell any. VR6 engine cover bolts are similar, but too small
  9. vrbanana Forum Junkie
    Sunny Sheffield
    ok, will do
    Cheers.
    Presume just the one old version to hand btw? Needing 2 ultimately..
  11. vrbanana Forum Junkie
    Sunny Sheffield
    you tart :lol: :lol: will have a look round for another one ;)
    Get into those bins!
  13. vrbanana Forum Junkie
    Sunny Sheffield
    Is it lunch time already???[:s] [:s]
    :lol: :lol: :lol: :lol:
  15. mk1. Forum Junkie
  16. vw_singh Events Team Paid Member
    I got one at home but not 100% on the grade or the size, but pretty sure its an m8.
    Gurds
  17. vrbanana Forum Junkie
    Sunny Sheffield
    Got a second one, will tell you how when I see you [:D] [:D] [:D] [:D] :lol:
  18. mk1steve Forum Member
    swindon
    ok whos 1.8t doesnt have a tensioner bolt now then:lol:
  19. vrbanana Forum Junkie
    Sunny Sheffield
    Someone is missing one :lol: :lol: cant say who [:$]
    Someone out there driving around without a cambelt? [:s] :lol: :lol:
    G - be interested to see what Daz turns up with tomorrow, but where's this one from? A VW?
