mk4 style stub axel on a mk2
Discussion in 'Chassis' started by MUSHY 16V, Jun 26, 2008.
  1. MUSHY 16V
    aberdeen
    i have all the parts to do a mk4 rear callipers on my mk2 16v but i wont to change to
    mk4 type hubs so i dont have to change the wheel barings ever time i change the disks
    i what i wont to no is watt car's have this hub and disk but in 100x4 stud
    do some seat's or polo's have this arrangement
    EDIT mk4 stub axles and hub do not fit polo or golf mk1/2/3 rearbeams or polo 6n stub axles
    thanks for that ryanp
    27/01/2009
  2. turbotommy Forum Member
    Newcastle upon tyne
    You need mk3 Seat Ibiza,they use the mk4 golf type rear calipers and are 100x4
    (wish i didn't weigh in the rear axle i had)
  3. Supercharged Forum Member
    Lupo/Arosa or Polo too
  4. MUSHY 16V
    aberdeen
    thanks alot both of you
  5. ryanp Forum Member
    Do the 5 stud stub axle and hubs bolt to a mk2.3 rear axle too??
    Either from a mk4 golf or a seat ibiza 5 stud.
  6. nealey Forum Junkie
    I would be interested to see how this all turns out as may consider it for mine
  7. MUSHY 16V
    aberdeen
    seems that thar might two ways of do this ether use a mk3 Seat Ibiza or Lupo/Arosa or Polo upto 2002 using the stub axle with the holes for the calliper carrie
    or use later Lupo/Arosa or Polo seat ibiza or mk4 golf stub axle and use a bracket from a lupo p/n6E0501466A or 6E0501465A dont no which one
    i am presuming that all bolt holes are the same but thay may not be
    and use the hub you whant 5 or 4 stud
    just bouncing ideas
    also depends on what i can get from scrapy
    will see what i can get from overprice on monday
    any ideas woud be appreshated
    27/01/2009
  8. MUSHY 16V
    aberdeen
    got some off a 2001 polo tdi 35
    and looks like a straight swap got all the nuts and bolts to just need disks and back plate's
  9. ryanp Forum Member
    Are the 5 stud hubs the same?
    cheers!
  10. MUSHY 16V
    aberdeen
    yes the 5 stud hub shoud fit the polo stub axle
    the mK4 stub axle will fit but it has on holes for the calliper carrier
    the mk 4 has this built in to the rear beem
    hence the use of the polo stub axle
    27/01/2009
  11. transitman Forum Member
    Any chance of a how to with all the party you used when you do this mate?? be really good!!
    Mark
  12. MUSHY 16V
    aberdeen
    will do mark
  13. MUSHY 16V
    aberdeen
    more parts arrived to day
    disk's and backplate
  14. MUSHY 16V
    aberdeen
    just a some photo of the new stub axle fitted:)
    old stub axle removed
    new stub axle and stone gard
    hub fitted
    brake disk fitted
    longer bolts for calliper carrier M10x1.25x30
    carrier fitted
    calliper fited
    finished
  15. nealey Forum Junkie
    what caliper carriers and calipers are you using?
    Also what are the carrier bolts from?
  16. MUSHY 16V
    aberdeen
    i have mk2 carriers fitted but mk3 will fit
    i am going to fit mk4 callipers at a later date
    i got new bolts form a industrial supply and cut to lenth as i had no carrier bolts from the polo
    but the ones off the polo woud do
  17. MUSHY 16V
    aberdeen
    hear is a list of part numbers used
    right side
    stub axle =6n0501118
    hub complete with nut and cover and ABS ring = 6x0598477
    splash shield = 6n06 156 612
    brake disk = 6n0 616 601a/b
    bolt stub axle to beam =n90758901 (4 of per side) M10x30
    bolt for brake carrier =n90740301 (2 of per side) M10x1.25x30
    left side
    stub axle =6n0501117
    splash shield = 6n0 156 611
  18. transitman Forum Member
    Would this be the same if I wanted to fit 256mm rear disks to my car with the brembo calipers from a Leon Cupra R??
    As the disks from the cupra would be 256mm and 5 stud, could I not use some 256mm 16V disks from the front of the mk2 to fit to the rear, thus making it 4 stud??
    Mark
  19. MUSHY 16V
    aberdeen
    i would say yes
    i have just tryed a rear polo disk on a front 16v hub and it fits
    do you have a Leon Cupra R rear disk
  20. transitman Forum Member
    Yes I will have a Leon cupra R disk come with the kit but it will be 5 stud....
