Baffled sumps
Discussion in 'Engines' started by Brookster, Sep 14, 2006.
  1. Brookster
    M1 J40
    Hello everyone:)
    can somone please email me a detailed drawing of a baffled sump detailing measurements for depths and sections. so that i can manufacture an aluminium one for my ABF lump.
    thanks [:D]
    Not sure if this helps:
  3. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Need a better baffled sump for mine as a had a bit of surge at times at Coombe last weekend. Any idea on price/availabillity on those Schrick sumps Chris ?
    They're around the 120-ish mark. Number of sources, some slow, some not so. Best to get advice on that before taking the plunge.
  5. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Cheers Chris. Not a bad price really, by the time i faf about with mine or buy another sump an re-baffle it i'd just as well go for one of those.
    Anyone any idea on a good supplier ? do the virtually cure any surge ? I'm guessing it's a 4 ltr sump ?
    Hmmm, I have a name recollection of Bahn Bremner Motorsport, but they're in Germany.
    GVK I think ordered one - sure he will see this thread...
  7. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Cheers. :thumbup:
  8. Sc0rian
    Sc0rian Forum Member
    Suffolk
    whats the improvement with them?
  9. fthaimike Forum Addict
    I have one on the 8v & the windage tray & for one thing it stopped my oil buzzer going off on heavy cornering :lol: .
  10. RobT
    RobT Forum Junkie
    Cheshire
    got my schrick one through Badger-5 on here - somewhere 120/140 notes
    Its ali (read soft), its got baffles, its the same capacity as normal, it can be used ok with a diesel windage tray with built in rubber gasket as the top is flat unlike a pressed tin one, you need to put spring and flat washers on and locktite to stop the bolts coming loose
    used mine with full slicks for 2 yrs with no problems - got rid of it as went full dry sump setup
  11. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Cheers chaps.
    When you say soft, i take it you mean easy damaged ? And normal capacity.. 4 ltr like the deep tin sump ?
    I've got a windage plate in my deep tin sump and baffle's but still had pressure fluctuation at Coombe so looking for a better solution. I had thought of a baffle plate accross the sump with some drain back holes but if the Schrick sump does the job it'll save a bit of messin about.
  12. RobT
    RobT Forum Junkie
    Cheshire
    the schrick sump does not have horizantle baffles, only the windage tray would do this, still was ok on my car providing half full of oil
    re soft....yes easily scuffed
    4L capacity
    try as I could, I could not stop oil leaking out of any of the sumps I have had, especially when running slicks - dry sump solved this completely but not cheap
    The Reeves Mk1 has the same sump, but doesn't leak. It's had a few scuffs on it over the years, and it runs a low ride height - no probs reported.
  14. Seraph Banned
    -5129' 57N-07 29W
    As nones answer yet!.........
    It aids oil delivery; baffels minimise the movment of the oil in the sump whilst flying around castle coombe at mach1!
  15. GVK
  16. Brookster
    M1 J40
    cheers for that what was the delivery cost ??
  17. GVK
    Can't think what the delivery was now, I think if you go to 'check out' but don't enter payment details it will give the delivery cost.
  18. POL
    pol Forum Member
    Scotland
    got a couple of sumps for my engines.
    got one of the sumps from the top of this page
    autotech sump
    pretty nicely designed, believe the design was taken from an old SCAT product.
    other one i have is a trap doored std sump tracksport done for me. was going to run this in combination with a std vw windage tray.
    p.s. on the windage tray don't pay the mark up 'tuners' add to a std vw/pattern part.
  19. nass Forum Member
    G-werks
    Littlehampton
    150
    Nas
  20. Fenn Forum Member
    Cornwall
    thers one on Bay ATM if anyones intrested?
