Slight knock from front of Mk2
Discussion in 'Chassis' started by Mikey, Nov 5, 2006.
  1. Mikey Forum Member
    (Car is a '91 Mk2 Gti with H&R springs & Konis)
    Today while stationary & idleing, if I move the steering about 2" from centre to the left & right, the wheels move as they should, so there's not much free play at all, but I can feel a slight knock from the pedal area inside the car, & while dad did this when I had my hand on the tyre, I could feel the wheel jerk slightly backwards by about 5mm ish (not much but it wasn't as noticeable on the passenger side) . Car has power steering by the way
    I've replaced the front & rear engine mounts not so long ago (August) so they should be ok.
    My front wheel bearings are suspect too because they drone slightly at speed - could this be a cause I wonder?
    I've a feeling that the top mounts are gone & they'll be replaced with VR6 ones this week. If these are shot would that cause the knock, or could a dodgy cv joint cause this too? (Noticed yesterday that the drivers side outer cv joint boot on my Mk2 had split so I'll have to sort that out this week.) The outer joint isn't clicking on full lock though so I think it's ok
    Sometimes I can feel the same sort of slight clonk when pulling off in 1st.
    I've checked the rear (vertical) fixing bolts for the wishbone & they are tight (Powerflex bushes fitted too). The inner cv joints have been mentioned to me, but I've never had a failed inner before - what are the symptoms if they're on the way out? The boots aren't split at all & the balljoints don't seem to have any play in them
    Anything else that could be checked? Just need some guidance on what to ask at the garage tomorrow
  2. funkbaron Forum Junkie
    New Forest/Southampton
    Sounds like you've covered most of what I'd think of - have you got the car up, removed a wheel and given everything a good rattle, see if it's present with no load on the wheels and whether you can isolate the sound with someone else steering?
  3. speedygti8v
    speedygti8v Forum Member
    market harborough, leicestershire
    have you checked the bottom ball joints?
  4. Vento Jim Forum Member
    Suffolk
    Check that the steering rack is tightened down to the subframe on both sides. Have you had the steering column out recently? If there's a cowling around the UJ at the bottom of the column it might be fowling as you turn the s/wheel. Or, there could be play in the UJ. Or, your rack might be making noises?
