For my mk1 cable change gearbox conversion, im off to the breakers tomorrow to pick some up but may have a problem in distinguishing them, does anyone know the length of them?
so if he has a rack full of drivehshafts up at the breakers mk2 golfs, mk3 etc etc! any with 100mm cv's will do? Surly the cab/scirroco ones are a differnt length?!!
you can mod the earlier shaft to take the larger joint by getting a couple of mill turned of the collar on the shaft were the joint sits,this allows you to fit the circlip
