head bolts..... to oil or not?
Discussion in 'Engines' started by Admin, Mar 26, 2007.
  1. Admin Guest
    further on from a thread the other week, concerning tightening down head bolts ( the thread was about bolts snapping, not for fear of wanting to do the same, i have seen a VW "expert" so it the other week;) :lol: [:$] )
    but keep them dry as they are supplied in the bag or very lightly oil them?
    seemed to have a mixed bag of opinions with it.
  2. Riley
    Riley Forum Addict
    Burnley/Lancs
    Personally...make sure holes in the head are blown out with air,and leave the bolts dry:)
    Never had a problem so far...touch wood:p
    Neil.
  3. vrbanana Forum Junkie
    Sunny Sheffield
    lightly oil every time without fail
  4. Admin Guest
    not bad twenty minutes and two opposite answers :lol:
    last time the bolts were supplied oiled up, this time i have them direct from the shop so they are dry,
    bolt holes are nice and clean.
  5. vrbanana Forum Junkie
    Sunny Sheffield
    When you buy them in sets most manufacturers supply copper slip to lube the bolts, its not just to look at :lol: :lol: :lol: Im sure Ive seen somewhere (possible autodata tech book) where it says before every torque setting to lightly oil the bolt threads
  6. Admin Guest
    haven't looked in the box properly yet[:$] its a bit like christmas here:lol:
    last set of bolts came via the garage, who had applied the copper slip to them, Crispy 8V (vw tech) who installed them didn't say anything about them being a bad idea like that.
  7. vw_stu Forum Member
    Wilstead, Bedfordshire / Coventry
    always always always lube headbolts before assembly. when dry they can bind slightly when tightening up, thus giving a false torque reading, and thereby not being tight enough.....plus there is the chance they will either snap (small chance) or go plastic (quite probable) when being tightened.
  8. paul_c Forum Member
    I oiled mine and it torqued up fine, and the engine runs just fine.
  9. sambo Paid Member Paid Member
    I was the one that kept snapping them:lol:
    Final time i did them i'v used VERY good quality torque wrench and just used bolts as they came(appeared to be oily) and all was well
  10. MUSH Forum Member
    cant remember....?
    i snapped them too, was my fault though, some come greased up and some dont, double check the holes are clean and very lightly oil the bolts, will torque up and remain fine.
  11. pRot3us Forum Junkie
    Wales
    copper slip :thumbup:
  12. Sciroccotune Forum Member
    just use them as tehy come, im sure they are pre lubed. just didnt mine no problems.
  13. SkyRocketeer
    SkyRocketeer Forum Member
    Here be dragns
    I can't remember where I read it, but it was a head gasket suppliers website, and they had a tech-tips section which made some interesting reading.
    Anyhow, they did a bit on correctly installing head bolts, and suggested lightly lubricating the threaded portion, and also between the bolt-head and captive washer, but not beneath the washer.
    Damn, wish I'd made a note of it..
    The tech tips section on the ARP website has got loads of technogobble for all you boffins.
  14. KeithMac Forum Junkie
    Kazakhstan
    ARP`s came with their own grease, to stop binding as someones pointed out already.
  15. Riley
    Riley Forum Addict
    Burnley/Lancs
    I should say...If i bought head bolts that came with a specific lube/copper slip id use it:thumbup: But they never have,so i never erm have [8(] :lol:
    Neil.
  16. maxmo
    maxmo Forum Member
    Co. Durham
    I have a set of head bolts for an 8v at home, I think they are febi. The sticker on the box says to lightly oil before assembly and they are already slightly oily.
    The torque seqence on the box is different to haynes aswell. It says two torque stages, then back off 90, then I think its tighten 90 degrees twice (or tighnen 90 then 180 degrees). Should I go with that or haynes?
  17. Sciroccotune Forum Member
    dont think you should be backing off with head bolts as they strech.
  18. Admin Guest
    for the 20v its 40Nm then 90 degrees, then another 90 degrees.
    see if engineering here have any spare copper slip.
  19. Alfa_Delta Forum Member
    County Durham, UK
    NEVER copper slip head bolt in - unless you intend to pull the engine appart in 10k miles due to gasket failure!
    I've seen this so many times. Who is it telling people to lube head bolts?!? Don't do it - ever!
    When you buy them, they already have the thinest of carbon lube on them, which is more than enough. Make sure the bolt holes are clean and dry and there is no swarf in them.
    If you copper slip them, they hyraulic - you then get a false torque reading - simple as that.
  20. Matt82
    Matt82 Forum Addict
    GTI Scene
    this thread has more conflicting info than any other thread ive seen before.
