ok i am attempting to fit an aftermarket ecu to my abf engined golf but i just cannot get a spark. now the ecu supplier insists it is my crank position sender or wheel at fault. i can see the wheel through the hole and it looks ok and it spins over with the engine. i have bought a new [pattern ] sender unit but to no avail. anyone any thoughts or anything as im stuck.
Is the ECU set up to the type of trigger wheel on your car? Not 100% sure but I think the ABF is a 60-1 wheel where as most aftermarket ECUs require a 36-1. I maybe wrong, but it's something worth looking into.
think it may actually be 60/2 but im not sure . i did ask for ecu to be set up for this engine but yes something for me to look at and type of suggestion i was hoping for cheers.
what ems are you running does the rev counter do anything when cranking the car over if it does then i doubt the vr sensor is naff more likely to be settings and yes 60-2 trigger wheel is what you have are the triggers set in the ecu ??
the trigger should be set in the ecu as i specified this engine when i ordered it but perhaps not. the rev counter dosnt move as i havent connected it yet as i havent sorted where to connect it on the car.
What ECU is this? Recheck wiring on 3 pin terminal of VR sender. 1 is - ve 2 (middle) is the signal and 3 is +ve. You may find you need to set up the trigger settings to run on wasted spark. Crank wheel is a 60-2 type.
Of course. What i'm saying is that half the members that replied to this thread have been away for a while. Your question is simple though and i'm sure someone will help you. I can't because i'm using another sensor
No bother, it'll have to wait anyway, going away working for the next 4 weeks so surely I'll have an answer by then
