Thanks for the responses re the return line (or lack of) in the other thread. It raised another question - namely that of running the correct fuel pressure. I'd be grateful if you could give me an idea of what psi you're running and with what engine/carbs. Thanks again.
3.5 psi, more than enuff normally, thats all I run on my 8v with 48's, but the carb size is largely irelevant
They just dont need any higher pressure's than above really, just enough to keep the fuel bowls topped up but not too much to cause flooding.
