What does your 16v rev limiter feel like!?
Discussion in '16-valve' started by DG370, May 30, 2007.
  1. DG370 New Member
    Hi peeps, my 16v KR seems to be hitting its limiter at 6500ish and its f**kin hard, like fuel cut in a jap car [:s]
    What do your limiters feel like, do they feel like most normal limiters in other cars where they just seem to hold at the redline?
    ive also just done the high limiter mod as per; http://www.clubgti.com/forum/showthread.php?t=104446&highlight=REV+LIMIT
    but it still stops at 6500ish just as before???
  2. pigbladder Forum Addict
    cambridge , uk
    mine a sharp cut off...like something has snapped lol
  3. iguana Forum Member
    Samoa
    7.2k & hits the Softy softy Pearl & Dean esk movie advertising theme,
    pa pa, pa pa, pa pa, dah dah dah
    change gear, lovely crack from exhaust & 3 foot flame
    jubbly
    :thumbup:
  4. pascal77uk Paid Member Paid Member
    Chelt
    Check you rotor arm is attached properly
    I had the same problem and symptoms the limiter was like hitting a brick wall. One day i hit the limiter it went bang and it came completly off thought id ****ed the engine wouldnt start etc, i fixed it and the limiters back to normal now check it out[:D]
  5. cometbluecoupe Forum Member
    yh - should be 7.2k thats what mine goes to. It is pretty harsh thou - only done it once in 3 yrs and that was by accident and it did feel like someone had slammed the brakes on.
    D
  6. GVK
  7. DG370 New Member
    Cheers for that, ill check the rotor arm pascal, i think my cars to early for the diagnostic trick, wouldv bin nice to do tho, il check my rev counter with a timing light or MOT equipment as u say GVK
    Pesky limiter! :p
  8. STU
    Stu Forum Junkie
    Cheshire, UK
    I've never hit the limiter in mine... do I drive like a granny? [:$]
    I did locate the limiter in my g/f's Lupo 16v Sport though and it was pretty harsh, thought I'd run over something hard! :lol:
