2litre conversion FAQs
Discussion in '8-valve' started by Rahul, Apr 27, 2004.
  1. Rahul Forum Junkie
    Why should you consider this conversion?
    Well, there is always that old chesnut with us dubbers.
    You ahve your 8v but the power just isnt as much as you want. You can't justify a 20vt conv, you dot want to sell your motor......
    Its 2litre bottom end time! [:D] :clap:
    ....coupled with a hot cam, gas flowed head and decent straight through exhaust you can get some good power and torque for hardly any money at all.
    The 8v gti in its standard form seems to keep a lot of dubbers amused as its pretty quick, but adding a 2litre bottom end gives you that extra grunt!
    The 8v golf is a much better car to drive that the 1800 16v as you dont need to rag the shyte out of it to get somwhere..
    Onto the conversion. [:D]
    What blocks can I use?
    The 2E, AGG, ABA, 3a, AWG, AWF engines from Various mk3 golfs, passats and audis.
    What should I pay for one of these blocks?
    Anything from free to 300 quid! These blocks are very solid so they should be in good nick providing the previous owners looked after the car with regular oil changes etc
    What head do I use?
    Well, your original PB head is fine for the job but while it is off you could get it ported and polished by your local machinist at a respectable amount!
    What do I do about Head Gaskets? Which one do I use?
    Mk3 one will do fine!
    Does the head fit straight on?
    It does. I used the AWG bottom end in my Cabby and it had one strange stud on the top of the bottom end where the head gasket mates onto it. There wasnt a hole in the Head Gasket for it so I just sheared it off! Heehee!
    What about Dizzys?
    You cant use the mk3 Dizzy . You need to use the mk1 one with the aid of a Ring available from TSR. Only about 20(I have one for sale!!!)
    How hard is the conversion?
    Well, I managed with the help of my mechanic mate and as long as you have an engine hoist( when doing it in the mk1s) you will be fine. Remember that mk2s the front panel can be unbolted and you can roll the car into the desired position.
    Is it worth it?
    Definitely. My car pulls so well, off the lights its great, point to point its great..
    Obviously, if you want out and out power then this isnt the conversion for you---->look to 2litre 16v or vr or 20vt..
    But I like it!
    IM LUVIN IT!!!
    Add this to the Engine FAQs please!
  2. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    What about chucking a full mk3 lump in?
  3. smithy Forum Member
    Scotland
    The mk3 head doesnt flow as well as the mk2 one so you wont get as much power out of it. However, it would be an easier conversion if you are already using digifant injection.
    Im considering a 2.0 bottom end myself but im concerned that it will make the car even less "revvy" than it already is. What kind of RPM does your motor tail off at rags??
  4. Rahul Forum Junkie
    5k ish i reckon...its all about the low down torque!!! :clap: .....i never look normally, but you can feel it. From what I have heard about your car from yourself, you have some great power from a driver....i think the 2litre bottom end will compliment the mods and making more driveable....obviously only in my opinion but lets just say i dont need to rev the fuk out of my car to have fun...whereas my mates with 16v's are really going for it when we race!
    Edited by: CabrioRags
  5. jc.. Forum Member
    Virgin Islands
    where do I find out what block goes with what car ie Mk3, passat, audi 80 etc etc.
    What are the differences in the different bottom ends?
  6. Rahul Forum Junkie
    there is not much difference to be honest, only age.
    The 3a and 2e are older ones from audi 80's and mk3 gti's respectively as well as pishrats! :lol:
    The rest are from golfs andlater pishrats....
    i wouldnt let that worry you to be honest....
    TSC will tell you.....he just got some 2litre blocks!
  7. smithy Forum Member
    Scotland
    It will certainly make for a torquey motor anyway. What it like against a standard 1.8 16v? I take it top speed is about the same, 120ish??
  8. Rahul Forum Junkie
    if you want top speed increase its not gonna be much.....but im not really interested in brown pants speeds to be honest...im a 0-100 man....no need to prove anything after that!
    But yes, similar to valvers!
    Smithy, best bet is to just DO IT! [:D]
  9. jc.. Forum Member
    Virgin Islands
    Pishrats?
  10. edc1 Forum Member
    2E and AGG also come in Seats.
  11. smithy Forum Member
    Scotland
    I can get hold of an audi 2.0 block for nothing, but the crank bearings are knocking (im guessing the oil pump went). One of my mates said he could get the crank done with new shell bearings for 40 quid. What do you think?
  12. jc.. Forum Member
    Virgin Islands
    So let me get this straight...
    Any 2 litre block from VW, Audi or Seat?
    does it have to be an 8v block to keep compression the same?
    There are lots of 2l 16v audi's lying around...
    How do you know what your compression is going to be like or are they all pretty much the same. If I am doing this then I want to keep my c/r high. Its currently slightly over 11:1 on my 1.8
  13. edc1 Forum Member
    No idea on the conversion - just wanted to add that if u were looking for a 2E or AGG then there are other cars aside from those already listed which you can plunder. Good thing perhaps with Seat is that they tended to get the engines a bit later than VW/Audi so may be in better nick eg AGG ws in mk2 Ibiza up till 1999 or even 2000; ditto for ABF which didn't make it to mk4 Golf (?).
  14. 1990
    Rochdale, Lancs
    Its Rags's Asian accent, he means Passat ;)
  15. jc.. Forum Member
    Virgin Islands
  16. Rahul Forum Junkie
    LOL!
    fecker...
    its only 2litre 8v bottom ends we are talking about.....not 2litre 16v!
  17. smithy Forum Member
    Scotland
    What sort of compression ratios do each of the 2.0 blocks give with a mk2 head?? Im guessing the one I can get out of that Audi is a 3A block, think its an F plate...
  18. jake Forum Member
    Saint Kitts
    Proper job Rags, this FAQ really needed doing.
    If I may add some...
    Breathers
    the 2E and many other 2.0 blocks have a crankcase breather system
    similar to the 16v. i.e. a baffled vent on the front of the block that
    plumbs into the inlet system. There are a number of ways you can
    deal wth this in a PB DX type replacement.
    1 Block it off with a plate (TSR etc. sell them or you could make one)
    2 Fit a tarty filter and vent to the air, K&N etc do small filters for this
    but you need the plastic manifold from the original block to help fit
    it. (i stuck a rag in the end of a fat radiator hose but I'm not someone
    to set an example of engineering standards here) If there is a lot of
    blowby then the smell will get on your tits though.
    3 Use the mk3 golf bits including the rubber pipes and do a factory
    looking job of T-ing it into the rocker cover breather.
    With K-Jet cars the distributor may need an adaptor ring if it is the
    one with the narrow body and the small gear on the drive end. The
    gear needs to be swapped too by knocking out the pin through the
    end (Swapping intermediate shafts doesnt work as they hit the crank
    in some applications I believe, I know PB int shaft hits the 2E crank)
    Edited by: jake
  19. Jettin' Forum Member
    UK, North West
    Most 2L blocks have a comp ratio of 10.5:1 or 10.8:1
  20. jc.. Forum Member
    Virgin Islands
    but the compression is s function of head space plus TDC space (piston crowns etc)
    If I stick a skimmed PB head on the wrong 2l block, do i run the risk of running silly C/R?
    Are all the pistons the same?
