FAO: 2.0L 8v converters - anyone got a pic of their plumbed in block-to-breather?
Discussion in '8-valve' started by mookie, Sep 16, 2007.
  1. mookie Forum Member
    Newcastle
    I'm looking to plumb in the front breather on my 2.0L conversion (I've used an Audi 3A block) and was hoping to see a few pictures of other peoples efforts. I think the only photo I've seen so far is Setones with the boiler pipes :clap: and was hoping to see a few more. Specifically how to go about it using the bog standard PB rocker cover and flying saucer etc.
    Failing that, any comments on how you've done it and with which materials would be spiffy
    P.S Setone, I remember you commenting that you were going to redo your first effort, did you ever do so?
  2. Setone Forum Member
    pics of breather pipes, i used some 22mm copper pipe, left over from when i moved my boiler
    there you go mate my efforts
  3. mk28vICED Forum Member
    Rugby
    managed to do mine very neatly after abit of fiddling round.
    using pb rocker cover etc. pics to follow...
    setone everything looks mighty black in there what did you use on the rubber inlet duct etc?
  4. mookie Forum Member
    Newcastle
    Would like to see some pics if you can?
  5. Mike_H Forum Addict
    Just stuff a rag in it ;)
    Tidy install from Setone, though!
  6. Setone Forum Member
    the pipe which is doing a u- bend type shape is 22mm copper pipe which i painted satin black, the pipe coming up from the bottom breather, is some electrical copex which i found at work and i used some rubber sleaving to join the 2.
    i use wd40 on all the black plastic's brings them up a treat
  7. mk28vICED Forum Member
    Rugby
    i stuffed a rag in mine to start with, vince at stealth didnt really worry about it either. [​IMG]
    was looking at all sort of pipe and stuff getting really annoyed.
    Then I got the original mk3 breather pipe out (bottom pipe) and noticed it was about 1/2" copper pipe size..cut a bit off the top of the pipe and using a copper 1/2" T-piece which i braised extra 1" lengths of pipe on, bolted the whole lot together with jubilee clips. looks much better now and happy in the knowledge nothing will get pressurised!
    Car seems to go better now too. really has much more bite than the 1.8. the gf even said it and we were only going slow. it just feels more solid and potent if i can use that word.
    clean as fook.
  8. i.a.n.b Forum Junkie
    Banbury
    Although still building mine up I've just blocked it up.
  9. mookie Forum Member
    Newcastle
    I've left it with a pretty OEM looking rubber stopper held on with a jubliee for the moment, i.e. blocked up. Not observed anything directly related to it being blocked, but like tinkering and thought I might try something on a par with Setones effort.
  10. i.a.n.b Forum Junkie
    Banbury
    I've used a coolant housing seal, bung and c clip, seems a perfect fit using genuine parts.
  11. mookie Forum Member
    Newcastle
    This is how it looks at the moment. Still tidying and neatening things up, but lots of tweaking means it's not getting a proper spruce until I'm happy with it mechanically.
    Engine:
    Close-up of the bung.
  12. mk28vICED Forum Member
    Rugby
    surely it was meant to be plumbed in.
    otherwise they wouldnt have devised such a complex casing from the two holes in the block.
    i guess it hasnt been long enough to tell any lasting effects of either.
    its looking all good mookie does it go well?
  13. mookie Forum Member
    Newcastle
    It was going like a true pocket rocket mate after I fannied about with the Colortune yesterday, until it went for it's re-MOT today and they totally messed up the fuelling. Now it's running like a bag of spanners and so I need to have another go myself.
  14. Dave J Forum Member
    Plymouth
    Here's my effort. 2E block with Pb rocker cover, but I used the round thing off the mk3 rocker cover.
  15. nobby Forum Member
    Is anyone running k-jet and a 2.0 bottom end? Does the extra breather get in the way of the WUR? I'm half way through building the block up now, but haven't decided whether to plate it up or use the mk3 breather.
  16. drunkenalan Paid Member Paid Member
    Leicester
    my car used to run a t piece like MK28vICED' car.
  17. drunkenalan Paid Member Paid Member
    Leicester
    with the breather blocked up, you are more likely to suffer oil leaks.
  18. mookie Forum Member
    Newcastle
    I've read that sort of observation before, but then I can't understand why TSR offer a plate to block it up? I've not noticed any oil leaks yet on mine, but I think if it's there it ought to be used properly tbh.
  19. i.a.n.b Forum Junkie
    Banbury
    Never heard that myself, whys that then? Maybe plumb mine in one day but more important things to sort on it first.
  20. nealey Forum Junkie
    what you mean like actually fitting it in the car???
