Rear Disk spacers for Berg wide track
Discussion in 'Track Prep & Tech' started by altern8, Jan 4, 2008.
  1. altern8 Forum Junkie
    Cocos (Keeling) Islands
    Does anyone sell these
  2. POL
    pol Forum Member
    Scotland
    not that i know of. best option is to run std wheel spacers. i would get hubcentric ones and don't go above 25mm. low offset wheels also help get the tyres 'out there'!
  3. Hotgolf
    Smelly Cornelly
    I can make you a set mate.
    Gimme a bell Saturday after 1pm, works nights :(
    Nooo Craig - how are they going to fit in the arches, or have you gone all Berg Cup !?
  5. GVK
    Just realised, no handbrake cable...
    pic is from the blue dutch mk1 ?
    Good point! Yep, Dutch Mk1.
  7. Dub Nutta Forum Member
    Gold Coast - Australia
    Surely fitting spacers like that increaces the torsional force on the tubular section of the beam and will cause a rotation which will in turn increace the negative camber of the rear wheel, which is not a good thing IMO!
    Also whats the extra peice of metal welded to the beam behind the shock mount, mabe it's some attempt at limiting the effect of the above.
  8. seanlazyass Forum Member
    Yes it will increase the torsional force on the beam, but as its the rear wheels the torsional force is minimal. I very much doubt it would be noticeable.
  9. badger5
    nr Glos
    you think? sticky rear wheels and rear beams bend big time!
  10. seanlazyass Forum Member
    The actual torsional stresses compared to the front wheels will be much less (FWD). But granted big sticky slicks will increase the amount of torsional/bending stress on the rear beam.
    Personally I think it would be ok. Plus I'd be surprised if that particular rear beam wasn't strengthened in some way.
    Related, though not quite spot on, but here's some interesting articulation images I found via Bildon:
    Rear wheel steer:
    One wheel bump:
    Undulations:
  12. fthaimike Forum Addict
    What would happen if you added the extra bits that the Reeves mk1 uses?
  13. prof Forum Addict
    Suffragette City
    nothing in that view
    they will stop the arms bending in towards the centre of the car tho
  14. seanlazyass Forum Member
    Do you have a pic?
    I remember seeing the setup but can't remember any details.
  15. fthaimike Forum Addict
    My mistake i thought we were talking about the bottom part being changed (that doesn't look as strong in the pic in 1st post), missed the spacers LOL.
    Should start reading more & not just looking at the pics.
  16. badger5
    nr Glos
    Having seen the Carvells Lupo buckle its rear beam tie rods, its clear the thing is moving around a lot more than I ever imagined... in a complex manner too, not just twist and bend but all of em at the same time.
  17. prof Forum Addict
    Suffragette City
    it's a design for a hatchback roadcar, and does a great job in that role at that cost.... proper racers have double wishbones [:D]
    Bill how far are you allowed to mod things within your regs?
  18. badger5
    nr Glos
    reasonably.. but some conflicting regs... cant increase track aside from mentioned mods like you can by moving ball joints (x) mm, top mounts (y)mm, adding fixed spacers "up to 25mm/side"
    I would'nt be allowed to space the rear hubs out I dont expect, but could add fixed spacers.. (not enough rear arch room currently)
    wheel size and offset is free also
    my rims are relatively low offset and wide for ickle ibiza.. (but wider front is run my the other ibiza 9" rims)
  19. prof Forum Addict
    Suffragette City
    so does it have to keep the old twist beam
    or could you use some fabbed rear arms? and seperate rear ARB.
    with minis they used to move the hinge point of the radius arms upwards, helped with pitch on acceleration
  20. badger5
    nr Glos
    you cant move mounting points I dont think.. that said pugs have run on different setups, not as factory fitted, so its maybe a grey area?
    ARB has to be outside the car, no rosejoints allowed on suspension unless it came from the factory with them.
    weird set of regs which clearly have evolved over the years to try and keep close racing from new cars which have come in.. just waiting for the turbo's to have their wings clipped in the 1800-3000cc class now, but the 2ltr non turbo wingers.
