Mk2 golf track car - Getting the old girl back on track......
Discussion in 'Members Gallery' started by steve r, Sep 4, 2007.
  1. steve r
    steve r Forum Member
    Heres a bit of info and a few pics of my trackcar.
    2.0l ABF, Megasquirt v3 ECU controls fuel and spark control using the extra software, Man in a shed head, ABF cams, innovate wideband LC1 lambda probe. Schrick sump
    VW motorsport 6 speed box, Peloquin Diff, All Smiles shifter, 14 point safety devices roll cage, Wilwood dynalites on G60 280mm discs (assisted chris eyre with bracket development), H&R ARB's (25/28mm), AVO coilovers, bucket seats, AW Tracksport fibreglass dash (flocked), sunroof structure removed, carbon door cards, Widetracked with arches rolled, Lexan windows, fully poly bushed (powerflex). 15x7" Compomotive MO's, Toyo 888's
  2. madmk4 Forum Member
    Pics of the cage please steve !
  3. dUff
    dUff Administrator Admin
    Liking the dash a lot steve !
  4. steve r
    Cheers, it took me a while to fit it [:$], and was a fair amount of effort but i'm glad i did it.
    front and rear section
    mounts to bulkhead behind dash
    also to sidewalls under dash
    Above windscreen
    At B pillar
    Had to remove the sunroof
    Original panel welded back in
  5. steve r
    I've now updated the megasquirt ECU to a v3 board and modified it to control fuel and wasted spark, this new ECU has been mapped by Toyotec
    I'm also trying a different inlet manifold thats a 16v lower section cut and welded to a 20v manifold. It frees up a lot of space in the engine bay and allows me to refit the eibach strut brace. I'll get the car to a RR soon to see the effect on power output.
    I also picked up another set of 15" MO's recently these came with clio cup slicks fitted
    I've also modified my gearshifter setup a fair amount, fitting bearings to the all smiles shifter and the tower in the box full thread here
  6. 91davidw Forum Member
    Northern Ireland
    Looking good Steve!!!
    Awesome car just gets better & better....
    David
  7. sparrow Paid Member Paid Member
    Leamington Spa
    Looking good Steve. Have you got any pics of the All Smiles shifter installed?
    Did you manage to fit the lower strut brace?
  8. steve r
    Cheers,
    this is a very old pic of part way through the initail installation
    I'll try to get an upto date pic this week.
    The lower brace didn't clear my 6 speed box [:^(]
  9. gillm
    gillm ***** User
    yeovil somerset
    love this car , just what a mk2 should be .
  10. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Yeah!!! I like it lots!!!
  11. Hawkesybaby Forum Member
    Tamworth
    Did you build/install the cage yourself dude? What figures do you reckon your pulling? Any differenve with the 20v mani on?
    Dan [:o)]
  12. James_mk2 Forum Member
    Farnham, Surrey
    do you have any more pics of the dash? what did you make it out of?
  13. steve r
    Thanks for the comments,
    My dad and I installed the cage ourselves, its a bolt in 14 point but strengthening plates have to be welded in at each mounting point, lots of work but we got it all done in a day. [:D]
    Not sure on power, it probably needs a tweek to the map as i've swapped the KR cams for ABF ones this week. I'll get to stealth when i've got time.
    Dash is an AW Tracksport one, made of fibreglass, heres a few pics:
    Plain dash cut to clear roll cage
    Cutouts for corrado adjustable height steering column and relocated clocks
    Removed the heated channel from the original dash to mount on the tracksport dash, holes were drilled in the dash to allow the air to reach the screen
    Back from flocking
    Heater controls moved
    Megasquirt connection point
    Finished
  14. steve r
    The best bit of the car. The reason i bought this particular car was because this was fitted to it. (A very very lucky find on autotrader [:D] )
    I then added a peloquin diff
    H&R ARB's fitted this week
    replacing Eibachs
    Lot of effort getting the dash right there steve - and a great job, what with the 'plain' starting 'canvass' !
    Plenty of nice parts on the car now, and look forward to seeing it out again.
    Do you still have the sunroof removal step-by-step, or is my mind playing tricks that there were more photos?
  16. steve r
    Cheers Chris, i'm looking forward to getting the car back out on track this year.
    The original sunroof removal thread is here but most of pics have died as they were in a picturtrail account that i no longer use, i'm up loading them to my photobucket account now so will try to edit them back into the thread.
    Edit: pics in sunroof thread now work.
  17. 12valver Forum Member
    Liking it alot, very nice spec and some neat touches
  18. Rainey Forum Member
    Nr Jodrell Bank
    If you don't mind me asking how muct has this all cost as i am looking to turn mine into a track toy.....
    Lot of work gone in there and its looking very good!
  19. steve r
    I'm not sure how much its all cost as i gave up trying to keep track of the costs ages ago.
    Lots of bits have been bought second hand and i've bought a few cars for certain parts and then broken them for spares to recoup the money. I would imagine its cost around 4-5 grand.
  20. doninphi New Member
    Lincoln
    This looks awesome, I dream of my car looking like this!!
