Differences between Golf MK5 GTi engines 200 bhp and 230 bhp ?
Discussion in 'Mk5' started by 444IN, Mar 10, 2008.
  1. 444IN Forum Member
    Croatia
    So anybody knows exactly what are differences between those engines, I know that 230 hp engine in Edition 30 is actually engine from new S3 Audi but powered down a bit but what are mechanical differences?
  2. Toyotec
    The new S3 motors have different cams, inlet path and turbo.
    "230" golf engine just runs a bit more boost.
  3. Sukh
    Sukh Membership Team Admin
    the driveway
    I've heard that the edition 30 has stronger internals as well. The same as the new S3 engine. So a stage 1 remap and you should see 300bhp and 295lb torque.
  4. micky1 Forum Member
    Bath.
    s3 and ed30 gti engine the same. stronger rods,pistons, injectors, fuel pump,ko4 etc
    ed 30,notice recirc pump down lh side of engine cover for different bov
    mk5 gti engine
  5. 444IN Forum Member
    Croatia
    In ED30 it's definitely not just some boost, for 30 hp gain factory always goes with other mods because it has to last and they are givin warranty for that so it needs to be well overdimensioned. That s why ED30 can put out 300 bhp with just a remap and with no worries.
    No way they will just add boost a little. Remember old 1.8t engines for example and differences between 180 hp version and 224 or 209 in old S3.
    What micky1 is saying makes sence they probably secured wth stronger internals also.
  6. sparrow Paid Member Paid Member
    Leamington Spa
    Don't know about the Mk5 cars, but the difference between the AUM 150hp golf and AUQ 180hp Golf was just a remap. Identical otherwise.
  7. PHIL18T New Member
    i thought the difference between the 150 n the 180 was 1 had a ko3 on it n the other was ko3s? mite b wrong like?
  8. Seraph Banned
    -5129' 57N-07 29W
    You're thinking of other 150hp variants of the 20vt, such as AGU and ARZ which have the KO3.
  9. 444IN Forum Member
    Croatia
    Nope you're right the run with k03s, I have somwhere written every difference and it is not just remap for sure .
  10. sparrow Paid Member Paid Member
    Leamington Spa
    I can assure you the AUM and AUQ are identical apart from a different map. Both DBW, both small port head, both KO3s.
  11. Toyotec
    Micky1 was right.
    The 230ps spec engine (BYD) shares the same block and head as the 256ps (BZC) and 265ps S3 unit (BHZ). I am not too sure on the integrated turbo/manilfold if the base turbo is a K04 but with different wheel trims.
    The 200 and 185ps variants (AXX, BWA BPY), have from my small reaserch, different head castings, inlet and outlet cams, fuel injectors, and turbocharger (K04 as well but different trim specs).
  12. Pricie Forum Junkie
    Heybridge, Essex
    I'd been informed by my man at Audi when i test drove the new S3, that there dry-sumped also.
    That's so unlikely to be the case.
    Dry sumped road motors aren't available this side of a 911 (IIRC) and Ferraris etc.
  14. Ben S
    Ben S Forum Junkie
    Essex
    I heard the next RS6 was dry sumped so maybe also the R8 V10
    but these are a liiittle bit more expensive than S3
  15. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    I'd be happier to go with Micky1 as well. The Ed30 engine is a detuned s3 engine which makes well in it's running specs
    when i get a mk5 GTI, I will only be looking for a Ed30
  16. micky1 Forum Member
    Bath.
    or get a mk5 gti and go for k04 spec like me! 300+ sooooon
    Some good info here folks.
    Micky, Toyotec - very interested in getting as much data down on these Mk5s as we can, so chime away :)
  18. DLBMKVGTI Forum Member
    manchester
    micky1 what fuel pump do you have??
    Getting an Autotech 2.0tfsi fitted next week,
    not to sure about this pump, apparenty REVO use it, is this true?
    anyway time will tell. :thumbup:
  19. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    do they do a higher spec/flow mechanical pump for these cars? and what is done with the pressure senders?
  20. Tristan
    I have to ask mate , you are a fountain of knowledge in Gti and Turbo Golfs...how have you amassed such info? Just honestly curious...and jealous!
