Does anyone (toyotec) have the pin out of the stock 1.8t cam sensor pin outs? wiring my s60 up.. assuming hall effect cam sensor, but does anyone know the pin outs for the sensor? thanks bill
3 pins... not on that link (which is very usefull btw - thanks) hall effect I'm sure, but not sure on their pin outs.
ive got a mk4 haynes but coulnt find it ill double check i never used mine as im running wasted spark lol
for AGU brown/blue to earth lilac/red to ecu T80/62 lilac/yellow to ecu T80/76 thats waht the haynes says
The pins for G163 "hall sender" found on AUQ and AUM engines from may 2002 are: 1 = 5v purple/green 2= Return signal to PCM purple/yellow 3= Earth brown/black Identical wiring pattern is found on Bosch hall distributors. I do not have specific wiring for AQX and AYP engines but would imagine that the above pattern will not change.
spot on.. you are da man although different OE wire colours on my ibiza pin out is much appreciated. mine for ref: 1 - green/red 2 - green/violet 3 - brown AYP ibiza std engine
