ABF Block & 9A head ?
Discussion in '16-valve' started by madmk4, Jun 9, 2008.
  1. madmk4 Forum Member
    Which head gasket is best ot use or does it not make any difference ?
    Are there any fitment issues should be aware of ?
    TIA,
    Mart
  2. madmk4 Forum Member
    Anyone ?
  3. James_mk2 Forum Member
    Farnham, Surrey
    Is there a reason you're using the 9a head? as with standard cams they are by far the worst vw 16v head, much better off with a KR or ideally the ABF head
  4. Brookster
    M1 J40
    if you use a KR Head make sure the piston clear the head, most KR Heads are fettled to fit the ABF Pistons.
  5. prof Forum Addict
    Suffragette City
    interesting as ABF cams have more lift? smaller exhaust valves on ABF IIRC
  6. madmk4 Forum Member
    There is a reason, which I realy can't be arsed to type out here lol..
    The engine the 9A head is on is producing 155hp ATW @7000rpm anyway so can't be that bad :)
  7. prof Forum Addict
    Suffragette City
    sounds a goodun mart
  8. madmk4 Forum Member
    Cheers, it certainly was untill the head gasket failed at the 'ring ! Still, it meant i landed a job there lol.
  9. Admin Guest
    Is this head on the pic from KR???
  10. Toyotec
    What is the part number on your 9A cylinder head?
