i have all the parts to do a mk4 rear callipers on my mk2 16v but i wont to change to mk4 type hubs so i dont have to change the wheel barings ever time i change the disks i what i wont to no is watt car's have this hub and disk but in 100x4 stud do some seat's or polo's have this arrangement EDIT mk4 stub axles and hub do not fit polo or golf mk1/2/3 rearbeams or polo 6n stub axles thanks for that ryanp 27/01/2009
You need mk3 Seat Ibiza,they use the mk4 golf type rear calipers and are 100x4 (wish i didn't weigh in the rear axle i had)
Do the 5 stud stub axle and hubs bolt to a mk2.3 rear axle too?? Either from a mk4 golf or a seat ibiza 5 stud.
seems that thar might two ways of do this ether use a mk3 Seat Ibiza or Lupo/Arosa or Polo upto 2002 using the stub axle with the holes for the calliper carrie or use later Lupo/Arosa or Polo seat ibiza or mk4 golf stub axle and use a bracket from a lupo p/n6E0501466A or 6E0501465A dont no which one i am presuming that all bolt holes are the same but thay may not be and use the hub you whant 5 or 4 stud just bouncing ideas also depends on what i can get from scrapy will see what i can get from overprice on monday any ideas woud be appreshated EDIT mk4 stub axles and hub do not fit polo or golf mk1/2/3 rearbeams or polo 6n stub axles thanks for that ryanp 27/01/2009
got some off a 2001 polo tdi 35 and looks like a straight swap got all the nuts and bolts to just need disks and back plate's
yes the 5 stud hub shoud fit the polo stub axle the mK4 stub axle will fit but it has on holes for the calliper carrier the mk 4 has this built in to the rear beem hence the use of the polo stub axle EDIT mk4 stub axles and hub do not fit polo or golf mk1/2/3 rearbeams or polo 6n stub axles thanks for that ryanp 27/01/2009
just a some photo of the new stub axle fitted old stub axle removed new stub axle and stone gard new stub axle fitted hub fitted brake disk fitted longer bolts for calliper carrier M10x1.25x30 carrier fitted calliper fited finished
i have mk2 carriers fitted but mk3 will fit i am going to fit mk4 callipers at a later date i got new bolts form a industrial supply and cut to lenth as i had no carrier bolts from the polo but the ones off the polo woud do
hear is a list of part numbers used right side stub axle =6n0501118 hub complete with nut and cover and ABS ring = 6x0598477 splash shield = 6n06 156 612 brake disk = 6n0 616 601a/b bolt stub axle to beam =n90758901 (4 of per side) M10x30 bolt for brake carrier =n90740301 (2 of per side) M10x1.25x30 left side stub axle =6n0501117 hub complete with nut and cover and ABS ring = 6x0598477 splash shield = 6n0 156 611 brake disk = 6n0 616 601a/b bolt stub axle to beam =n90758901 (4 of per side) M10x30 bolt for brake carrier =n90740301 (2 of per side) M10x1.25x30
Would this be the same if I wanted to fit 256mm rear disks to my car with the brembo calipers from a Leon Cupra R?? As the disks from the cupra would be 256mm and 5 stud, could I not use some 256mm 16V disks from the front of the mk2 to fit to the rear, thus making it 4 stud?? Cheers Mark
i would say yes i have just tryed a rear polo disk on a front 16v hub and it fits do you have a Leon Cupra R rear disk
