I'm trying to do some homework on EFI (Megasquirt) and I've come to a bit of a dead end. I have no idea how to go about mounting a 36-1 tooth wheel to the crank! Can some one please advise me? An even when it's on, how do I go about mounting the sensor? Thanks in advance. Gary
If it is a 9A or KR unit the trigger wheel should be mounted on the crankshaft damper. The pick up can be mounted via a bracket bolted to the block
