spark plug dti holder
Discussion in 'Tools, Equipment & Fasteners' started by gillm, Aug 21, 2008.
  1. gillm
    gillm ***** User
    yeovil somerset
    right guys i have borrowed a tool that holds the dti in the head to gain true dtc . im told it is vag only as i can't find 1 anywhere !
    where could i get 1 as its a pukka tool
  2. vrbanana Forum Junkie
    Sunny Sheffield
    That’s new on me, never seen one but I’d be interested to see one. I use a magnetic block that holds the dti and an extension to reach down the plug hole
  3. Hotgolf
    Smelly Cornelly
    SAme here, I put a solid bar down the hole to sit on the piston then use a dti ontop of that.
    I usually do it with the rocker cover off, also with the dti base removed and then screw the dti shaft somewhere on the head
  4. gillm
    gillm ***** User
    yeovil somerset
    i will get a pic tomorrow for you guys
  5. vwgolfgtinut
    vwgolfgtinut Forum Member
    Catterick Nort Yorkshire at the moment
  6. vwgolfgtinut
    Part number 2068A Made by Matra
  7. gillm
    gillm ***** User
    yeovil somerset
    nope and bollox i forgot to take a pic
  8. vwgolfgtinut
    describe how it looked and i'll se what i can do
  9. vwgolfgtinut
    you doing bore measurements?
  10. gillm
    gillm ***** User
    yeovil somerset
    about 8" long and the dia of a spark plug with a thread on 1 end to screw into the plug hole and a 5mm hole threw the centre
  11. vwgolfgtinut
    or you trying to det top dead centre?
  12. gillm
    gillm ***** User
    yeovil somerset
    yeh its for tdc
  13. vwgolfgtinut
    you tried the whistle version? or just the one with a pin through?
  14. gillm
    gillm ***** User
    yeovil somerset
  15. vwgolfgtinut
    you can uy them where you screw it in to the cylinder head in the spark plug hole whilst tuning the engine once the cylinder is on compression stroke the air is forced through the whistle and once the whistle stops thats you at TDC cheap as chips to buy just trying to remember the company that does em in uk
  16. gillm
    gillm ***** User
    yeovil somerset
    thats also sounds good
  17. vwgolfgtinut
  18. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    similar to that one, the VW part is more solid, whichs allows the DTI screw in and the base of that screws in the spark plug thread
    FYI : it's used soley (at the moment) for checking the TDC on 1.6 FSI engines which are chain driven, with no other way of checking the crank timing!
  19. gillm
    gillm ***** User
    yeovil somerset
    as promised
  20. gillm
    gillm ***** User
    yeovil somerset
    no-one knows then ?
