KR cams in an ABF.
Discussion in '16-valve' started by PAB, Sep 26, 2008.
  1. PAB
    PAB CGTI Regional Host
    Mansfield Notts.
    Hi all.....again, ok could you help me out? Whats the deal with fitting KR cam shafts into an ABF engine? it seems quite popular...
    Philip.
  2. lufbramatt Forum Member
    Rochester, Kent
    dont, no point. ABF cams have better specs than KR ones. The popular swap is for the KR cams into a 9a.
  3. Brookster
    M1 J40
    ABF INLET & KR EXHAUST is a good one.
  4. PAB
    Mansfield Notts.
    Thanks boys, sorry for my lack of knoledge but whats the advantage with the KR exhaust cam in the ABF?
    Philip
  5. sambo Paid Member Paid Member
    Preety much even stevens duration wise, abf has more lift
  6. Mike_H Forum Addict
    I'd keep the ABF cams - both of them.
  7. Toyotec
    Yup. Stock ABF Cams work quite well ;)
  8. crezz Forum Member
    yeah no point in changing tbh
  9. mk2vivs Forum Member
    on a 9A tho?
  10. Mike_H Forum Addict
    ABF cams would be good on a 9A too, or a KR inlet is the 'traditional' option.
  11. Hotgolf
    Smelly Cornelly
    I've tried both these as a test a few years ago. Had then in a stock 1800 bottom end with a flowed head/modified valves.
    Yes there's more lift on the ABF cams than the KR, but when in use I found the KR's more agressive due to the sharper opening and closing flanks and longer dwell. Basically the sides of the cam are steeper, opening the valves quicker, then the top of the cam is quite rounded and not pointy like the ABF's, so the valve is open longer at full lift.
    The ABF's felt far smoother, and didn't get the 'coming on cam' feel thats associated with the traditional 16v.
  12. mk2vivs Forum Member
    ive got a 9A and i bought a stealth modified exhaust cam for the inlet side.is this a good option?cheers
  13. mk2vivs Forum Member
    the 9A came with the 42mm inlet manifold.would it be any good to fit the 50mm manifold i have as well?bit off topic but i appreciate the help.bit new to all the 16v/8v stuff cheers
  14. G60Dub
    G60Dub Forum Member
    Angus
    Thats an interesting point Mart - It would be interesting to see the KR and ABF cam profile plots overlaid.
  15. Mike_H Forum Addict
    Have a search for Toyotec's investigations on different cam options.
  16. Gambit
    Gambit Paid Member Paid Member
    still no actual RR figures to compare to see what difference there is. ABF cams & KR cams in a 1.8 16v
    although i think phil is gonna have a rattle at it in his 1.8 16v for some conclusive proof
  17. G60Dub
    G60Dub Forum Member
    Angus
    Hi Mike,
    I've read over Toyotecs posts - Kr's are longer duration but less lift. ABF- slightly less duration but greater lift, subtle difference in overlap too. I think more could probably be gleaned from overlaying the profile plot of each set of cams? That's a question mind - not a statement- I know very litte (read as b*gger all about automotive engineering) and I'm looking at this from a simple physics standpoint. I guess the maths gets complicated very quickly when comparing cams with similar duration/lift values but again I guess it comes down to horses for courses and each cam set could be better suited to a particular application?
    Edit: Maybe, given the physical properties of the 051/053 castings - perhaps the ABF camset is a more 'refined' desgin whose starting point was the KR cams?
    Again though what would be the intention? Performance or drivability.
    I'll get my coat as at the end of the day they only way is to model the system and/or perform quantative testing.
