Did any MK2s come with pollen filters?
Discussion in 'Miscellaneous Technical Queries' started by EZ_Pete, Nov 26, 2008.
  1. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    My '91 Driver has a grille in the scuttle with 4mm(?) holes in it to stop whole leaves getting in; but Shirley, over the years, smaller bits must get through and clog up the airways through the matrix?
    Do the Gti models have the sophistication of a pollen filter?
    Where's the easiest access to get a Dyson in there and suck out some crud from the matrix?
    Ta muchly :)
  2. DAVE 2227 Forum Junkie
    Looks like parts 43 & 44.
    Discontinued accessory by the looks although I am sure I have seen one before but not like that.
  3. EZ_Pete
    Ah, thanks Dave.
    Looks like the proverbial rocking-horse excrement may be easier to find then. :lol:
    Will have to see whether I can't improvise something.
  4. nealey Forum Junkie
    me and i.a.n.b have been thinking about fitting a mk3 one as they look like they will fit, we still havnt actually got around to trying this theory though
  5. Finite
    Northamptonshire
    Tried to buy one of those in the late 90's it was discontinued then I stupidly bought the filter first its been at the back of the garage for around 10 years [:$]
  6. Trev16v
    Oxfordshireland
    Never seen such a filter on any of my MK2s! Not on the G60, and not even on our old South African MK2.
    I reckon it's probably worth asking this on VWVortex. Wouldn't surprise me if the US guys had it.
  7. EZ_Pete
    Hmm, good idea Trev, I may just try that.
    Nealey/i.a.n.b: I could give the MK3 version a try, will try to visit a scrappie this w/e.
  8. pigbladder Forum Addict
    cambridge , uk
    obselete in the u.s too , was a upgrade available at the dealer as far as i know
    there was a u.s parts seller that had a few , was on the vortex not long back( i expect lhd is differant though)
  9. i.a.n.b Forum Junkie
    Banbury
    We must get round to this! Let us know if you have any joy with the idea before we do Pete.
  10. MUSHY 16V
    aberdeen
    the mk3 used the same parts for the pollen filter as the mk2
    so on luck there
    unless you can get one from a scrap yard
    the top of the inlet vent is the same p/n on both mk3 and mk2
  11. EZ_Pete
    Well I've just splashed out for a MK3 filter on E-bay, so I'm committed to finding a bit to put it into now. [:o)]
    Anyone breaking a MK3? ;)
  12. neil kaye Forum Junkie
    england
    y a pollon filter needed in winter brrrrrrrrr anyway a solution for the leaves problem,get a pair of the wifes tights and wrap them over the grille in the scuttle this way you dont get any leaves no matter how small going down the grille and the added bonus of when you turn the fan on you have a nice eroma of gusset bringing home the meaning to a hard ride;)
    Seanie vw likes this.
  13. EZ_Pete
    The more air I can blow through the matrix, the warmer the car is...
    But having seen how quickly the pollen filter on my g/f's Omega 'blacks up' (she likes to blow a lot...) I don't fancy running my cabin fan on high speeds knowing that I'll be breathing all the grit and dust that the scuttle can collect.
    It's bad enough that one has to breathe in the carbon/copper dust from the motor brushes, 'black lung' anyone? [xx(]
  14. Trev16v
    Oxfordshireland
    Pete can use his own tights.
  15. EZ_Pete
    How very dare you? [:x]
  16. Mike_H Forum Addict
    Note: Fishnets are no good.
  17. rubjonny
    there is a SEAT model which uses the same pollen filter assembly as the Golf, I canne remember which but I'll try to dig out the infos...
    edit: well that was easier than I thought it would be :lol:
    Alternate source guide
    VAG filter element is 'mahle LA/ LAG19', same as fitted to 91-99 Toledo
    clicky
  18. GVK
    :lol: :lol:
  19. EZ_Pete
    ...just a posh description of a pair of tights? :lol:
    Sorry [:$], usually try to avoid these puns.
    I'll have to see if I can find that Knecht one, cheers John. :thumbup:
    EDIT: I'm all confused now...
    The Sussex Club "How to" is great, except it fails to mention the part numbers for these Knecht housings, and my quick Googling isn't helping yet.
    The VW housing is obsolete for MK2, but if I vagcat a '93 MK3 I get a part number 1J2819640A, still showing as available at 10.75 Euro.
    No.19, and probably 21:
    Is it just the Nissan-hut-shaped filter elements that can't be had from VAG any more??
    Edit2: Hmmm, on closer comparison, the MK2 'option' filter holder and the Mk3 one are subtly different. Guess I can bodge the MK3 one in though.
  20. mattneck Forum Member
    I have a mahle filter element tihng here.. let me dig the pic up.
