ABF / 9A / 6A Head gaskets are they the same?
Discussion in '16-valve' started by Steve B, Jan 15, 2009.
  1. Steve B Forum Junkie
    Manchester
    Slightly off topic form the other head gasket thread so thought id start a new one
    are 6a 9a and abf gaskets all the same i can get a reletively cheap ABF steel gasket thats good quality, it would be for a 6a block with a KR head (i know the KR gaskets are different and not reccomended on the 2.0li blocks
    thanks
    earlier 9a/6a gaskets are fibre, later are steel as per abf. short answer: yes, use the abf gasket :)
  3. Steve B Forum Junkie
    Manchester
    ok will do thanks!
  4. DuBDuDe Forum Member
    South London
    I just picked up my 9A head gasket from VAG but stupid me forgot to order the steel
    9a/abf one and i have a composite one.
    pn 048 103 383 B
    Does it matter? OR should i swap it for a steel.
  5. DuBDuDe Forum Member
    South London
    Just compared the old 1.8 gasket with the new supposed 9a gasket and the 9a does look maybe up to a 1mm bigger all the way round. how much bigger should the bore size be?
  6. DuBDuDe Forum Member
    South London
    it's ok just checked the sizes i have got the right size but it's still a composite one. I'm just going to use it anyway.
  7. rubjonny
    yeah should be reet, not like you ever hear of early 9as or MK3 8v blowing their gaskets :)
  8. DuBDuDe Forum Member
    South London
    all good the. head going back on today just having a ***** ling the cams up grrr
  9. DuBDuDe Forum Member
    South London
    whats the torque setting for clinder head bolts and procedure foir doing them up i cant fiund it in the gayness manual. Bloody thing doesn tmake sense.
    i found the bolt sequence but cant find anything else about it.
  10. rubjonny
    its in the 1.3 section :)
