On one of my itb's the trumpet wobbles slightly where the sealant appears to have come away from the body. Clearance is tight to the bonnet and there is a slight rubbing of the paint-i might remove the thermal insulator from between the head and body to cure this?? Is there a specific sealant i need or will anything do?
Any ideas on this people? not managed to find anything specific so i assume anything heat resistant will do??
do you mean the glue beteween the aluminium spinning and the cast bit that fastens it to the end of the body (2 holes in it)?
yep, thats the area-just looks like it has dried and started to come away-nothing major but as i'll be transplanting it soon i thought i might aswell get it right
