2036cc ABF 83.5mm 16V MS1 V3 & Jenvey 45mm DTH 200bhp + Project
Discussion in '16-valve' started by Brookster, Feb 28, 2009.
  1. Brookster
    M1 J40
    Well the time has come for the 2.1L 16V Build.
    So time for the 2.1L 16V Build
    ABF Block bored to 83.5mm (2036cc)
    Integrated Engineering 159mm H- Beam Rods
    ARP Main Studs
    ARP Head Bolts
    ARP Crank Studs
    Eurospec Crank 92.8mm
    83.5mm Forged Pistons (JE Pistons)
    and need to decide on the rest of the shopping list.
    [​IMG][​IMG][​IMG]
  2. Mike_H Forum Addict
    Have you checked the con-rods in the old engine to check they haven't gone oval at the large end, or that they're not slightly bent?
    BTW, I spent a few quid with Integrated Engineering last week - thanks for the recommendation. I mentioned your name too.
  3. Brookster
    M1 J40
    The ones i'm gont to use are Brand new con rods i got last month from Integrated Engineering last month, all the ARP Gear is new too.
    I'm just waiting for Pete @ Int to get back to me with a piston price, don't think they can do JE in the spec i want but i think they do Mahle.
    Which pistons did you go for Mike ?
    The ones that went today were standard rods and pistons, Nige P blew three pistons today a Donny Track day so he wants my old Pistons, like you say don't know if the rods will be any good to him but i have a few more spares.
  4. Brookster
    M1 J40
    Has anyone got any good links for Billet Cranks for teh ABF 92.8mm.
    Mike what crank are you using ?
  5. sambo Paid Member Paid Member
    Brooksters, how about eurospec ones?
    Mike, what are you building, somethink juicy?
  6. Brookster
    M1 J40
  7. sambo Paid Member Paid Member
    Got a eurospec one in my audi, cant fault it, at high revs is smoth as
    No nasty vibrations
  8. Brookster
    M1 J40
    Bildon havn't got any cranks just got e-mail fro them, just waiting for the Eurospec to get back.
  9. Brookster
    M1 J40
    Just sourced a Eurospec Crank from Neal H
    Cheers Neal :thumbup:
    will fit the ABF Trigger wheel straight to it.
    Just Pistons now to get.
  10. sambo Paid Member Paid Member
    I was just about to post a link for this item! Well done brooky
  11. Brookster
    M1 J40
    Just need the Pistons now.
    Looking for JE Pistons 83.5mm 10.5 :1 comp, waiting for a few prices back.
    Going to drop the block off tomorrow for the 83.5mm bore.
  12. Mike_H Forum Addict
    Why the low CR? Is it for a forced induction engine with stacked gaskets, or does NOS work better on a 'normal' CR?
  13. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Is your trigger wheel an internal (o.e) type ?...if it is, DONT FIT IT !.... they can explode and make a bid for freedom via a new hole in the block. Only use an externally mounted trigger wheel for peace of mind & wallet.
  14. Brookster
    M1 J40
    Cheers for that, i do already have a 36-1 trigger fitted external as i was going to run an EDIS Unit, so think that will be a good idea.
    Mike - i'm going standard compression with the Nitrous set up i'm running.
  15. Brookster
    M1 J40
    Just order the Crank sensor bracket and Dizzy balnk plate from Eurospeed as detailed in the kit below.
  16. Brookster
    M1 J40
    The old block is now stripped and going for the 83.5mm Re-bore tomorrow @ Hindles Bradford.
  17. Mike_H Forum Addict
    You're not mucking about here, are ya?!
  18. Brookster
    M1 J40
    need to get it running and run in asap, missed all last year's racing due problems and don't want to miss this year.
    I hate running it in thou, up and down the A1 @ 50MPH Behind a wagon , did it twice last year only to find a different problem.
  19. Red_n_dead Forum Member
    London, south.
    Guess you've previously done head work, what figures do you think you'll get with the rebore alone?
  20. Mike_H Forum Addict
    I read some interesting views on here on running in. In summary, it was that the best way to bed in rings is to decelerate from about 60mph in 3rd, using the pressure on the overrun to bed them in quickly.
    I'm not sure that long gentle running does much.
