could anyone give me the p/number for the dizzy oil seal for the shaft ( not the o ring ) or let me know where to get one cheers neil
i have looked in to this but not got round to doing it yet have a look hear http://www.clubgti.com/forum/showthread.php?t=174242
cheers for the pm i have been around four places today and have now got 10 seals on order so lets hope they are the right one's should get them in three to five days will let you no i they are any good well i get them
another one I got the seal from simply bearings, i used the lippy one like in the guide. to get the metal serrated ring out i just twatted all the dizzy internals out thru the top, the 2 brass bushes arnt a mega tight seal so it wasnt hard. To refit it I put the bushes back in the same way, then placed the serated washer on the dizzy then used a large flat socket to tap it back on fully.
nice one that sheads a bit more light on this the ones i got are not as cheep[:^(] mind you there not much in it and i have no postege on top i had one place that wanted 5.68 each in the end i was 2.00 each
still 2.00's nothing,better than buggering the hall sender up ,the one ive taken out is rock hard and chipped,must have got very warm at some point
good job you saved that guide john its always better with pics,i think im going to start saving usefull stuff,just incase ppl decide to take the pics off
i think ill get sme of those seals too mushy is this the one you got john http://simplybearings.co.uk/shop/shopping_cart.php
was that the two fiber washers you where on about i dont think you can get them if that's one's john got it is the same one's i have on order 12x19x5 the green o ring 027905261 is not cheep from vw have you the old one to get a size from
na i just assumed the green o ring was that part number cause is sat on that packet with the info on,i dont need the fibre washers iv got the old one and my mate has the correct size diamiter ones but the green ones seem to be a bit thicker
