Why is there a block of metal bolted to the engine subframe?
Discussion in 'Chassis' started by tomstickland2, Jun 17, 2009.
  1. T
    tomstickland2 New Member
    I replaced the engine subframe on my mk3 Golf yesterday.
    Why does the subframe have a large block of metal bolted onto it?
  2. Riley
    Riley Forum Addict
    Burnley/Lancs
    Its just a dead weight for balancing :thumbup: Not sure what it balances exactly though...
    Neil.
  3. C8
    Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    I've asked the same in the past, seen many on them but make no sence
    why would you need to balance a 1800 single point injection 5 door GL?
    good news is they make great metal working blocks
  4. Brian.G
    Brian.G Forum Member
    West of Ireland
    is it really? always thought it was to ''redirect'' drive and other bits in the even of a crash? are we talking about the block with the angled edge on it?
  5. V
    vrbanana Forum Junkie
    Sunny Sheffield
    It’s a vibration damper, quite a few manufacturers use them in various positions, you need to see the lump of steel on the back corner of the TT’s
  6. RM
    RIP-MK3 Forum Addict
    sunbury on thames
    is handy to hold the driveshaft up too......
  7. L
    lufbramatt Forum Member
    Rochester, Kent
    yep
    adds mass to the subframe to move its resonant frequency away from the frequency of vibrations created by the engine so you dont get loads of noise in the cabin.
    rolls royces etc have loads of them dotted around the whole car.
  8. P
    pigbladder Forum Addict
    cambridge , uk
    took mine off ...doesnt seem to make any differance
    might have done on a brand new one i spose
  9. G60KG
    G60KG Forum Member
    at work 'working'
    so is it not advisable to take it off, my corrado as one and its heavy enough as it is :lol:
  10. badger5
    nr Glos
    get rid of it.. easiest weight saving you will make.
    its got to weight 2-3 kg's
  11. Brian.G
    West of Ireland
    well ill be damned!
  12. S
    sambo Paid Member Paid Member
    Got rid of mine ages ago while doing abf swap in my rado
    just couldn work out what it does so i binned it
  13. C8
    NW
    it makes sense, think i need couple on the mk 4 then!
  14. tallika_fan
    tallika_fan Forum Member
    Northwich
    as stated it's a harmonic damper for balancing out vibrations etc.. they even put some in buildings, Taipei 101 par example
  15. T
    It's not a damper...it's a mass.
    Anyway, I know what you mean.
