I was in the scrappy today and noticed how fat a passat anti roll bar was. Would this be the same shape a MK2 golf, as that would make an ideal cheaper option for a uprated roll bar for my VR6 conversion. The wish bones looked the same and im assuming that the sub frame is the same.
Well thinking about it ive used the MK3 VR sub frame with the MK2 wish bones so i suppsose i just need to know if it will fit on that set up.
iirc theyre a slightly different shape, but not sure how. passat subframe doesnt fit on a golf shell, its a bit wider. careful what spec passat you get it off- only the GL and GT spec ones got the thicker 24mm ARB. heres a pic if any use, anyone have a golf pic to compare?
I have a passat ARB in the garage, couldn't fit it on a mk 2 i recall the mounting points don't align, hence the bends make it impossible to fit on a mk2 subframe
Wrong wrong wrong You CAN fit the the passat bar to the MK2, pretty simply. Its the same shape, just a lot thicker. The passat subframe is different at the points where the subframe bushes fit, the passat is bigger and wont fit the MK2 subframe. You need to get poly bushes and drill them out to work with the passat bar. It will then bolt on.
Sorted and a great tip then - mega easy and cheap front ARB upgrade for a Mk2 Just leaves the back to sort!
The passat arms use the same pick up point locations as the MK2, thats why you can wide track using the passat arms and not have to change the ARB - it all fits. The picture above shows the two bars have the same end and bush positions. VR6T is doing a similar thing type on his Rallye, using a thicker G60 Passat Syncro rear ARB as an Upgrade, again slight differences in bushes etc but it will go on. For the rear i guess you are stuck with an aftermarket ARB, or investigate the differences with a Passat rear beam.
OH yeah and about the back. Theres isnt one is there ? Where do they go then ? Cheers for the info on this guys, off to the scrappys now. Although the car is on the bottom of a pile of three so im not sure how im gonna get that little bugger off.
I have a j plate passat ill be breaking soon, 2.0 bottom end for the mk1 and wide track and hydro pedal box + cable change box for the mk2. I was hoping that the rear beam will bolt straight on as it might be wider? anyway ill be investigating as soon as I get it back off my parents who wanted to borrow for a week 2months ago
Right well i have the same problem as crispy 8v mentioned. Although im trying to fit this to a MK3 sub frame. The bar on the passat bends up where it needs to lay flat for the bracket. Have i read into this wrong ? Will it only fit the mk2 and not the MK3. I hope not it was a bugger to get it off a the scrappy.[:^(]
Ive now just offered it up to a MK2 sub and its the same. Its hard to get a bracket over never mind one with a drilled out bus in side. I think im going to grind a few mm's off the bar to level it out where the bracket meets up.
I realise that but at 24mm surly i have a few mm to play with. Just had another go. Theres no way its going on, you cant even get a bracket over without a bush on, never mind one with a drilled out bush. Plus ive been using the larger passat bracket. It really just doesn't seem possible.
its the same when you fit them in a proper passat subframe- took all manner of clamps and molegrips and swearing to get mine on- in a passat. i found that dropping the buches in hot water for 10 mins helped, gives them a bit more "give"
