Hi, Does anyone know if these are available to buy or will I need to get one laser cut myself? Thinking it will be MUCH cheaper to buy a mass produced one and have the tubes tig welded locally. Thanks for any help!
just grab your self a std manifold and get it cut up at an engineering company the milled flat will be prob cost around 100 i know a company that can do it
These are the ones I've had made: If you are interested in the flanges let me know. The pictured ones are stainless but they can also be cut in aluminum.
How different is the NA 20V inlet as it's ready to bolt carbs onto? Plus it's got injectors and a fuel rail.
http://www.034motorsport.com/index.php?cPath=50_47 i used one of the 16v exhaust headers as a spacer to advoid the exhaust manifold melting the inner cv boot
