16 metering heads
Discussion in '16-valve' started by NealP, Jul 2, 2004.
  1. NealP Forum Member
    If some of you 16v owners are looking for a decent size metering head you can get them straight from Volvo. They are larger than the VW item similar to that of the VW motorsport jobbies. It is however a fourteen day turn around and they want half the money up front. Price is 690 inc vat and the part number is v05003509. Volvo discription is N/STK fuel distribut.
    Neal
  2. davidwort Forum Member
    690 quid :o
    TBH, I don't think there's anything wrong with the standard one until you want to go well over 200bhp with a valver.
    David.
  3. NealP Forum Member
    David.[/QUOTE]
    Totally agree David. Had Martin Woolford's MK1 16v solid lifter in yesterday, it will rev to 8500rpm but wont supply the fuel to match. Only relevant if your going wild I suppose?
    Neal
  4. Vduber Forum Member
    wot cars are they off?????
  5. NealP Forum Member
    Volvo 240 2.0l Turbo. 1985-89.
  6. Vduber Forum Member
    ya can get them off scrap yards then.... [:D]
  7. NealP Forum Member
    Yes mate. Martin tried that approach, ended in tears though. Imo with a car thats pushing 8500rpm I would want the piece of mind that the thing will work and not go belly up on me!
    Neal
  8. Joe_G Forum Member
    Great Britain
    If I was going that serious with an engine tho, I'd just go for twin Webbers or Throttle Bodies if I could afford it. The main drawback at those revs tends to be that the K-Jet can't supply enough air, not fuel.
    For 700, you could get a much better way of fuelling than std. K-Jet.
    Joe
  9. octane Forum Junkie
    but throttle boddies woudl require injection still? so you'de need to go to digi or something?
  10. Joe_G Forum Member
    Great Britain
    Yeah, you could go for direct to head throttle bodies with say Peugeot management or full aftermarket programmable stuff if you could afford it.
    Joe
  11. Vduber Forum Member
    you could go for g60 managment with the SNS tuning normal asperated chip set to your spec.
  12. GVK
    bump
  13. RO
    Ro Forum Member
    Cambridge
    nice bump gary.... good thread...
    but
    you really should get a job!!!
