Just wanting to double check The return line is blue/green. The supply line is black. FSE valve setup like so Cheers
Fuel filter mounted using the Old Coil Bracket. New Banjo fitting used for Fuel supply line from Filter to Injectors Fuel Return Pipe FPR Requires a bracket making FPR Mounted and Fuel pipes connected
