Running ITB with a turbo on a VW 4 cyl?
Discussion in 'Throttle bodies & non-OEM ECUs' started by Lennard, Nov 8, 2010.
  1. Lennard
    Lennard Forum Member
    I was just wondering if anyone had done it?
    Yes, but it's not common. Folk use 1.8T manifolds / adapt 16v ones as reqd.
  3. Lennard
    Are there any threads that go from a normal turbo TB to an ITB setup, I know the general rule with turbo charging is to worry about the exhaust side of things due to the pressure created on the inlet but I would still like to see what performance gains there are.
    Since I quite like the idea of a GT28RS with an ITB setup.
    I've not seen anyone do it in a while. Jenvey TBs I believe are good for holding pressure, but the packaging around them is the issue, all bespoke fabrication?
    It was done in the mid-90s, possibly with carbs. I would hazard a guess, given that the WRC crowd opt for carefully designed plenums to spread air to the cylinders, that it's an interesting technical exercise, but possibly one that doesn't yield results.
    Injector spray patterns could suffer?
  5. Yoof Forum Member
    If you want ITB & Turbo combinations, check out some Nissan Pulsar forums- came with this set-up as standard, and there's plenty of them with large power.
    Chris- What's the thinking behind injector spray pattern suffering?
  6. Lennard
    They might be limited by regs, i'm looking at extreme hill climb still to see if there's anyone using that kind of setup.
    Random porn I just found:
    Twin TB? Can't quite tell... looks like a carb?
    Just thinking aloud - short stretch of tract with high air speed. Happy to be wrong about that.
    Something lingers about this being relatively uncommon way of doing things.
  8. Lennard
    Don't happen to have a pic of the XL7 twin turbo v6 engine do you?
  9. Lennard
    I think you're probably right, I know the BMW S52 engines respond well to turbo/super chargeing though and they're ITB?
  10. Lennard
  11. Lennard
    God the yanks are demented: http://zilvia.net/f/tech-talk/112321-pulsar-gti-r-itbs-sr20det.html
    Cheers for the info though, i'll keep digging...
  12. Lennard
    Waiting on a response from the guy who built this engine:
  13. badger5
    Jenvey have a turbo planum solution now to accomodate this
  14. sambo Paid Member Paid Member
    Andy Nichols runs itb-s on his turbo rover, i'm sure i have some pics from a race day this year at the pod, il dig them out tmrw
  15. sambo Paid Member Paid Member
    Come to think of it, looks very much like this set up
  16. sambo Paid Member Paid Member
    Here is a pic i had in mind
  17. Brookster
    :thumbup:
  18. prof Forum Addict
    Trendy Tramp used then on his super/turbocharged beastie, I think it just simplified the pipe run
  19. badger5
    there are options on the jenvey pleum to use bodies or single body so its pretty flexible, and can mount different ways side to side, upside down etc. incredibly light!
  20. Lennard
    The big question though.... is it worth it badger?
    Any data to show increases in response/power?
