OE VR6 & V6 engines list & outputs
Discussion in 'VR5, VR6 & Wx' started by Toyotec, Apr 7, 2011.
  1. Toyotec
    12v
    Engine code + valves Years Model fitment Capacity cc Bore mm Stroke mm Power PS@rpm Torque lbft@rpm C/R Comments
    AAA 1992-1998 1H Golf, 3A Passat, Corrado, Sharan, Galaxy 2792 81 90.3 174@5800 179@4200 10:01 Was controlled by M2.7, M2.9.1 and M3.8.1 and M5.9.1(in OBD2 US applications) available world wide to run 95 RON with reduced performance using RON91.
    ABV Corrado storm, Golf 3 & 3A Passat* syncro 2861 82 90.3 190@5800 183@4200 10:01 Was controlled by M2.9.1 and M3.8.1 * Passat Syncro was rated 181PS available only in Euro. 98 RON
    AES Tranporter 4 Merc Vito 2792 81 90.3 140@4750 179@3200 10:01 Engine has modified camshafts and inlet manifold to improve low down response. RON 95
    AFP* 99.5-01 USDM 1J GOLF/JETTA 2792 81 90.3 177@5800 181@3200 10:01 Was controlled by , '99 & '00 -M5.9.2, '01 -ME7.1( E-Gas). Variable manifold. Calibrated for US RON 93
    * Some very late production 99.5 mk3's came with a AAA engine using AFP sensors
    Many an enthusiast and lay people tend to identify the physical changes to the 12v VR6 engine between 1994 to 1995 as "OBD1 and 2" This is because the engine controller was changed to incorporate legislative directives that would relate to US markets as the OBD2 std became mandatory in the US as of 1996. The ECU software features between Europe and the US do have significant differences mainly due to diagnostics as most of the European OBD functions are switched off and will be calibrated for different fuel quality. The ABV 2.9 was not available outside of Europe as the minimum fuel with reduced performance was RON 95. This engine came with both M2.9.1 and M3.8.1 controlers, with the later controllers fitted to the Golf 3 syncro and the Passat Syncro. AAA abd AES engine can be operated with RON 91 fuel with a reduction in performance.
    24v
    BDE/AQP/AUE 1J Golf 4 motion 2792 81 90.3 204@6200 200@3200 10.5:1 Controlled by ME7.1.1
    BDF '02-04' USDM 1J Golf and Jetta 2792 81 90.3 Controlled by ME7.1.1 Calibrated for US 93 RON Fuels
    AXK '00-'03 USDM EUROVAN 2792 81 90.3 204 200 10.5:1 Controlled by ME7.1.1 Calibrated for US 93 RON Fuels
    AXJ Beetle RSI 3189 84 95.9 228@6200 238@3000 10.8:1 98RON with reduced performance running 95RON, controlled by ME7.1.1
    AZZ Toureg 3189 84 95.9 218@5400-6400 228@3200 11.25:1 98 RON, controlled by ME7.1.1
    BDL Transporter T5 3189 84 95.9 234@6200 235@2950 11.25:1 98 RON, controlled by ME7.1.1
  2. Toyotec
    Tuner engines
    Engine code Years Model fitment Capacity cc Bore mm Stroke mm Power PS@rpm Torque lbft@rpm C/R Comments
    AAA Any BRM 2792 81 90.3 205@???? 17%more@3500 ? VSR manifold, 270 cams, K&N, Jetex exhaust system
    ABV? 1992 2861 82 90.3 214@???? 201 @ 6,000rpm ? Nothelle CVR6/3 conversion (4.15k)
  3. Toyotec
    Race engines
    ABV Any Golf 3 VW cup 2861 82 90.3 238@???? TQ@rpm ? Motec (ver?)
    Just starting to dig out info.
    BR Motorsport (tuner) - VSR inlet plenum, 270 cams, K&N, Jetex. 205 bhp ("up 30 on std"). Torque up 17% @ 3,500rpm. Not 100% whether this is a 2.8 or 2.9.
    VW Cup Mk3 VR6 (race) - 2.9, 238bhp current spec. Motec mgt.
  6. coullstar Forum Member
    Scotland
    Grant Motorsport did some decent work with these engines as well. Obviosuly for more ABV specfic info the corrado forum is a very good source of the good (eg Schimmel 263's) and bad (bore ovality) for this code.
  7. Toyotec
    I am on there and do see comments like that.
  8. Capt.Dreadz New Member
    AFP came in 99.5-01 MK4 (Some very late production 99.5 mk3's came with a AAA engine using AFP sensors).
    12v
    '99 & '00 -M5.9.2
    '01 -ME7.1
    We got BDF code for all mk4 24v VR6 in the US. ('02-04'). ME7.1.1
    I have a few "tuners" & "race" spec's for you to add. A few shop's here in the states have 250hp 12v's. I'll compile a list.
  9. Capt.Dreadz New Member
    One of the pioneers here in the states. KCR Racing
    04' R32 block
    Custom JE 89mm bore 14.1 comp
    98 vr6 92mm crank
    Schimmel performance rods
    06' 3.6 cylinder head
    welded all extra coolant and oil port to match r32 block
    Full Ferrea valve train
    KCR custom 3.6 downpipe
    KCR custom intake manifold
    Another KCR car. I dunno the spec's
    There are alot of N/A VR6's. 95% are running Lugtronics SEM.
    Many thanks for the OEM upates in post 8. I have ammended them back into post 1 in blue. Hope that reads ok :thumbup:
  11. Toyotec
    Small tweak to the above.
    USDM = United States Domestic Market.
  12. Capt.Dreadz New Member
    Special Ed. maybe :lol:
  13. Toyotec
    <Shakes head and thinks FAIL!:lol:>
  14. Apsik New Member
    Poland
    2.8 24v
    BDE is ME7.1.1 ECU - 2 wideband O2 sensors, both cams equipped with hydraulic adjusters just like R32
    AYL found in Sharan and Alhambra - 1 wideband O2 sensors, both cams equipped with hydraulic adjusters just like R32
    AQP, AUE uses ME7.1 ECU - 1 wideband O2 sensor, hydraulic adjuster for intake cam
    3.2 24v "gen MK4" (ME7.1.1 older are "K-line version" read/write in boot mode)
    Golf 4 - BFH, BML
    Phaeton - AYT, BKL, BRK
    Touareg - AZZ, BAA, BKJ, BMV, BMX, BRJ
    Transporter - BDL, BKK, BDM, CFLA
    TT 8N - BHE, BPF
    !! If you want to SWAP R32 engine and keep Cruise Control System use Golf or TT ECU's because others connects directly to steering column electronics, not to the switch.
    3.2l 24v "gen MK5" (cams with runner length compensation, all ME7.1.1 ECU "CAN version" can be read/write through OBD, ABS VSS)
    Golf 5 - BUB, CBRA
    Passat - AXZ (the only TRUE 3.2 FSI !!! has the same head as 3.6 BLV and MED9.1 ECU)
    EOS - BUB
    A3 - BDB, BMJ, BUB
    TT - BUB
    3.6l 24v (MED9 ECU, in 2008 cams has been changed on most 3.6l engines)
    Passat - CDVB, CNNA, BLV 280hp, BWS 300hp (R36)
    EOS - CDVA 260hp
    Phaeton - CHNA 280hp, CPFA 250hp, CMVA 280hp
    Touareg - BHK, CGRA 280hp, CMTA 250hp
    Q7 - BHK 280hp
    Those are my personal notes. May not be 100% accurate. However I wired many of those engines :)
