GTI / VR6 Cat Converter
Discussion in 'Mk3' started by kells, May 9, 2011.
  1. kells Forum Member
    LEEDS
    Are these all the same size bore ?
    got Bam engine for my MK3 and im unsure if i use the 8v Cat or need to source a 16v item
    any help would be great
  2. Matt82
    Matt82 Forum Addict
    GTI Scene
    8v = 50mm
    16v and vr6 = 55mm
  3. kells Forum Member
    LEEDS
    Do u know if I can use my cat ??
  4. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Bam uses 2 lambdas. Think you can go for a 2nd lambda delete and go for a sports cat. Depends on the downpipe you are using but would say your 8v cat would be restrictive.
    This may work without the 2nd lambda delete. I have one to put on.
  5. tshirt2k
    Herts
    all MK3 8v, 16v and vr6 use the same size cat, 8v has a smaller exhaust from the front silencer back, but the frotn of the silencer is the same diameter as the 16v and vr6. there are differences over the years though, some of the cats are shorter in length
  7. tshirt2k
    Herts
    My 16v cat is around 700mm long. The replacement hi flow cat is around 500mm long, so had to get an extender piece made up for it.
  8. kells Forum Member
    LEEDS
    ok guys i have a guy willing to sell me the ABF Gearbox, gear selector thing, CAT and flywheel all for 150,.. what do you think?? and will i need the pedal box from the ABF or is the 8v one ok ??
    Tshirt2k, where did you get that decat and how much was it, do i deffo need to run both lambdas if i run a cat, if so do i use these off the donor engine or the the one thats in my cat now ??
    im new to this so any help here would be so good mate.. and the party starts in a week or 2..
    Also will my car fail the MOT without a cat?? on emmisions, its a 93 car so should really have one on
  9. kells Forum Member
    LEEDS
    BTW im going for a Qpeng downpipe
  10. tshirt2k
    Herts
    Then the flange fitting will be different that the 16v/ vr6 one. Your car needs a cat for the MOT to pass. A BAM engine would use two lambdas if it's past 2001 upstream and downstream of the cat. That's if you're using standard management. Although I have heard of 2nd lambda delete?
    Are you? Or using qpeng management too?
    Bit more detail is needed for what you are running. As most on here have decat due to age of the vehicles. Don't think qpeng downpipe has a flange, just a straight pipe.
    The cat shown is from 42 draft designs in the US. Worked out fairly cheap around 170 at the time.
  11. kells Forum Member
    LEEDS
    my engine is from a 2003 cupra R.. im using the factory management. now looks like iv bought a full mk3 16 v abf car to break fior the parts i need
    any other info you need matey ?
  12. tshirt2k
    Herts
    Ok so you're using front end, gearbox, converting to hydro clutch etc. You wont be using the 16v cat if you are going with qpeng. It probably restrictive and has 1 lambda bung. You could maybe get one of those cats i suggested earlier, cut the flange off and connect to the qpeng downpipe.
    It up to you whether you are remapping the ecu as you may be able to get the 2nd lambda delete at the same time. But that cat has provisions for 2 anyway.
  13. kells Forum Member
    LEEDS
    So can i not use the 16v cat at all ? do i need to use the pedal box from the 16v too ??
    im going to remap it also once its all fitted
  14. tshirt2k
    Herts
    I wouldn't use it. If you try to. It would mean adding a flange to the qpeng downpipe.
    But by the sounds of it you just want to use factory management and remap once it's in? So you'll need. 200cell min cat with 2 lambda bungs to satisfy the management. So 16v cat will be no good anyway.
  15. madmanmart Forum Member
    Staffordshire
    All Mk3 pedal boxes are the same but you will need to add the hydro clutch setup to yours if your using a 16v box.
  16. kells Forum Member
    LEEDS
    cheers re the pedal box matey
    Tshirt2K can you supply me with a link for a CAT i need to get, Many thansk for your time btw :-)
    just bought this GTI 16v, its bloody mint!!!! and runs so well even tho it has suspect head gasket fait (oil in coolant expansion tank - but engine oil looks good)
  17. nealey Forum Junkie
    Bet its not the headgasket but the oil cooler collapsed!
  18. turbotommy Forum Member
    Newcastle upon tyne
  19. tshirt2k
    Herts
    I've seen somewhere the qpeng ones failing at the welds too.
    The vr6 cat is from here. Depending on the exhaust you have you can get it with a reducer or 2.5" straight though.
    Email them for postage costs to the Uk. They'll send you a paypal invoice iirc. Very helpful.
  20. kells Forum Member
    LEEDS
    So if i use the Downpipe turbo tommo lists and the cat you list can i run both lambdas ?
    this is blowing my head off haha, You are a great help mate thanks for you time
