The VAG-COM / VCDS owner directory thread.
Discussion in 'Vagcom / VCDS' started by Trev16v, Jun 19, 2011.
  1. Trev16v
    Oxfordshireland
    Having seen something similar on the Corrado forum that I browse quite a bit, I thought it's worth creating a thread of all the people who have VAG-COM (or now known as VCDS) who are happy for help someone read fault codes and whatever out of their car.
    So I'll start.
    I have VCDS-Lite, fully functional with a paid licence. I don't *yet* have a commercially-bought lead (I will get one), but I have built my own interface and successfully used it to talk to our Corrado 16V's KE-Jet ECU which I know few seem to have success doing.
    I'm near Wantage, Oxfordshire.
  2. shaz8389
    shaz8389 Forum Junkie
    I have VAG-COM and are in ze West London area.
    Getting a new laptop screen within the week so I'll be fully functional to help out if anyone needs it.
  3. sparrow Paid Member Paid Member
    Leamington Spa
    I have a full VAG-COM cable. It's the USB version that can read up to the Mk4 Golf paltform. It can't do Mk5, Touran, etc.
    Located in Leamington Spa.
  4. Toyotec
    I have the the full licensed version with VAS5051 adaptor (2x2) for older K line vehicles pre 95 plus later J1962 connector for later K-line and EOBD (CAN) vehicles.
    Located in West London.
  5. Trev16v
    Oxfordshireland
    Le bump.
  6. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    This was tooked away in the engine section
    Lost for good??? :lol: might need updating
    I have full Professonal lead, inc Can Bus inc 2x2pin adaptor
    Covers everything from mk3 right up to 2011 car vehicles,
    Based on the Wirral
  7. MUSHY 16V
    aberdeen
    i have VCDS 10.6 with a vag 106 cloned lead and vag tacho 3.01
  8. StuMc
    50? 20` 47 N - 06? 57` 57 E
    I have a V-checker Pro. It`s an emulation of the old VAG1552 diagnostic reader, but will read everything VAG that has an ODB port (including all current models). Doesn`t do 2x2 though.
    Apparently can be used to read blocks and alter stuff as per VAGCOM, but I haven`t worked it out yet! But it`s perfect if you just need codes read/cleared.
    Based in South Manchester
  9. rubjonny
    I have vag-com and vag-tacho, location is bracknell/berkshire
  10. m1keh Forum Member
    Full version of VCDS lite and cheapy ebay lead. Devon until September then Leamington Spa.
  11. tshirt2k
    tshirt2k Forum Junkie
    Herts
    I have VCDS full version i also have a clone 805.2 version that covers newer platform mk5, touran etc. and vag tacho. Can do miles to empty, dash light changes on the mk4. Cluster swops.
    South London, East london, Kent, Essex/Herts Borders
  12. Admin Guest
    yeah don't PM to update it though. put it to the powers that be:thumbup:
  13. iwanaturbo New Member
    I have full licensed VCDS with 2x2 lead aswell and all software for dash changes/ecu changes and mileage correction.
    I'm in TRURO CORNWALL
  14. Dan W
    Dan W CGTI Regional Host
    Penryn, Cornwall
    I have access to vagcom, although I'm very close iwanaturbo above.
    Penryn, Cornwall
  15. rich81 Forum Member
    Winnersh, Wokingham
    I have Vag-com and vag-tacho. Happy to help out members for free no problem. In Reading.
  16. Matt82
    Matt82 Forum Addict
    GTI Scene
    Essex
  17. LregG
    LregG Paid Member Paid Member
    If you have a pre 2000 car then I have a copy of vagcom that will work with your car...I live in Alton GU34 and work in Guildford GU1
    PM me if you require assistance
  18. modded a3 New Member
  19. Collie Forum Junkie
    Adlington Lancs
    checked the 3 fuses on the battery? how did you assertain that a new ecu was required?
  20. modded a3 New Member
