Engine mount problem. Help!
Discussion in 'Mk3' started by nickid, May 30, 2012.
  1. nickid Forum Member
    Stevenston Scotland
    Hi all. rebuilding my mk3 cab 2.0 8v and found that all the engine mounts are no more.
    One one the drivers side, metal bracket is cracked and bracket to starter motor is snapped, and all others rubber are crumbling.
    Problem i have is finding the parts i need.
    left and right rear
    front centre[​IMG]
    left and right sides?[​IMG]
    I can find the rubber bits for all apart from the left and right side, and also need the drivers side bracket.
    CAN SOMEONE [:^(]HELP
  2. nickid Forum Member
    Stevenston Scotland
    pics added
  3. danster Forum Addict
    Very interesting seeing the engine and gearbox mounting to the chassis legs rather than the subframe.
    That is similar to how the old works Golf rally cars were done. I presume it is to do with the Cabby shell design.
    Is the engine code AWG out of interest. Possibly a search on ebay for that engine or whatever type is fitted will throw up someone breaking one that may still have the mounts you need.
  4. nickid Forum Member
    Stevenston Scotland
    the code on the v5 says ADY
    where would i find those mounts that are on mine if they aint the usual ones
  5. Stewy
    Stewy Paid Member Paid Member
    Midsomer Norton
    I have one of these if it helps from a AGG should be the same???????
    [​IMG][/IMG]
  6. Jagermeister
    Jagermeister Forum Member
    Being Trolled
    from VAGCAT
    x2 options for 35 they are:
    1E0199732B -bonded rubber mounting right rear /
    1E0199732C -bonded rubber mounting right rear / 1Z,AHU,AFN, ALE
    39 is 1E0199731A -bonded rubber mounting left rear /
    The front as Stewy says looks to be plain vanilla front engine mount, maybe hockey pucks may sort you there, but the part numbers are:
    1H0199609F -bonded rubber mounting white / manual- gearbox: AAM,ABS,ADZ, ANN,ANP
    1H0199609B -bonded rubber mounting green / automatic: ABS,ADZ,ANN
    1H0199609G -bonded rubber mounting brown / 2E,AEK,ADY, AFT,AGG,AKS, AKR
    1H0199609J -bonded rubber mounting / 1Z,AHU,AFN, ALE
    From personal experience Vagcat numbers can be out of date, but they can be a good starting point. HTH
  7. nickid Forum Member
    Stevenston Scotland
    Thank you very much for going out of your way to find that out for me. I couldn't find a mount or a picture of the mount on any other car I needed it
  8. Stewy
    Midsomer Norton
    So do you want it ???? if so pm me [:D]
  9. nickid Forum Member
    Stevenston Scotland
    Where does it go
  10. Stewy
    Midsomer Norton
    Its is the Front bracket that holds starter motor and front engine mount
    [​IMG][/IMG]
  11. nickid Forum Member
    Stevenston Scotland
    Oh! The middle front bracket is fine mate. It's the starter motor that has a bit broken off
  12. Stewy
    Midsomer Norton
    Confused[:s] Looking at the Pic you are showing the front bracket - which bit of the starter has broken off
  13. nickid Forum Member
    Stevenston Scotland
    The bracket onto the starter motor is attached to a piece of the motor it bolts onto
  14. Stewy
    Midsomer Norton
    So u need a starter motor ??? as this is the bracket that the starter attaches to after the bolts go through the bell housing
  15. nickid Forum Member
    Stevenston Scotland
    Vag cat is no more.
  16. Jagermeister
    Being Trolled
  17. nickid Forum Member
    Stevenston Scotland
    nope no joy. thes must be custom mounts. they are not listed anywhere for mk3 and have been looking at mk1 and 2 to see if they are the ones
  18. lewp91 Forum Member
    Hertfordshire, United Kingdom
  19. nickid Forum Member
    Stevenston Scotland
    thanks mate will check link. ye the upper driver side mount is split also and i did think about a weld but was going to buy the whole mount
  20. nickid Forum Member
    Stevenston Scotland
    i think the mounts are custom mounts. every site have the same mounts for the two rear and one front mount. there is no mounts for the left and right upper ones
