2.0 16v (nissan) ricer head probs ;-)
Discussion in 'Engines' started by mark25, Oct 30, 2004.
  1. mark25 Forum Junkie
    Rotterdam
    All,
    i know it's not a VW, but i need to to get the head bolt undoing sequence for a '95 2.0 16v NISSAN [:$] primera, ASAP?
    Or, anybody recon i could just follow the VW pattern?
    Also, how to align the cam chain timming marks for head removal would useful, i haven't seen it yet tho.....
    Or where to look on the web to find the above out.
    Tvery muchIA
    Mark
    Edited by: mark25
  2. mark25 Forum Junkie
    Rotterdam
    hasn't anyone played with one of these?
    M.
    Nope, but the head bolts hould be undone in the same way as any iron block/ally head engine (if that's what it is!), they all have the same sort of order to pop the bolts in for a good reason - to stop the head bending up like a banana..... so the VW method would be fine.
    No idea at all about the cams I'm afraid.....
  4. mark25 Forum Junkie
    Rotterdam
    it looks like an ally block! cheers TSC
  5. TheSecondComing Forum Addict
    In that case I'd be inclined to slacken them all off bit by bit, with the engine stone cold.... ally head and ally block should be fine that way. Probably best to do them from the middle out anyway, just in case....
  6. Golden Forum Junkie
    Don't you just throw jap stuff away when it breaks? :lol:
  7. mark25 Forum Junkie
    Rotterdam
    it wouldn't be broken if the father-in-law hadn't just driven it 10 miles with no water! But then again, if it's such a crap design that the temp guage reads normal under those conditions........(bottom hose blew off)
    Mark (whose faith in VW is rising by the minute!)
  8. mark25 Forum Junkie
    Rotterdam
    it's only got 2 head bolts proper, as above, there are some 10mm head bolts around the outside of the head too tho....
    small outside ones first ??? anyone ???
    M.
  9. Golden Forum Junkie
    Don't trust me on this I just nicked it from a NIssan site! :lol:
  10. mark25 Forum Junkie
    Rotterdam
    cheers m8!
    M.
  11. mark25 Forum Junkie
    Rotterdam
    oh dear it's warped by 1mm. one of the head bolts was loose too. Does anyone think the head warp may have ripped the head bolt out of the ally block?
  12. KeithMac Forum Junkie
    Kazakhstan
    That`s a bit of a warp! don`t think that would pop a bolt out though, maybe last person in f**ked it up?
  13. mark25 Forum Junkie
    Rotterdam
    one owner fsh car! it did make a "snap", type noise while it was cooling from the severe overheat tho.....
    Inetersting looking at the head tho, the manifolds are well matched, the gaskets are a lot better fitting than VW (8v) ones too and there's no obvious restrictions in the combustion chamber when the vales are just open. A novice, like myself, could not get anything out of it IMO, unlike VW where you can feel the improvement of a few hrs with the dremmel. I guess that's why the nissan spares are more expesive tho.......
    I'll try and post some piccies, soon.
    M.
  14. mark25 Forum Junkie
    Rotterdam
    a bit less extra meat than on a VW 8v head, the gasket is has less play on the bolts too.
  15. mark25 Forum Junkie
    Rotterdam
    less obstruction at 50 thou lift than the last 8v VW head i worked on.
    Edited by: mark25
  16. prof Forum Addict
    Suffragette City
    actually it's a nice engine that, all alloy too.
  17. mark25 Forum Junkie
    Rotterdam
    Yeah, i see some good things going on, buy i'm not too sure the followers are the best for high revs or extreeme (VW type) longlevity tho.
    EDIT: although i did read it was designed to be V. quite, so less followers/lobes may be to do with that.
    Edited by: mark25
  18. prof Forum Addict
    Suffragette City
    sometimes they use the rocker arms to lever a bit more lift from a compact cam lobe
