1.8T 20V Engine codes FAQ
Discussion in '1.8 & 1.8T' started by Michael Ghia, Oct 31, 2004.
  1. Michael Ghia Forum Member
    I have been checking out the archives and the postings on 1.8T 20V engine codes so as to put everything onto a list.
    So far I have 26 different engine codes and the different things I'm noting are the following:
    BHP rating
    Compression ratio
    Vehicle fitment
    Date used
    Cast or Forged crank
    Head port size
    VVT or not VVT
    Internal or External Water pump block
    Turbo used
    Cable throttle or Fly by wire
    Injector size.
    If anyone has this info on any of the 1.8 20V engines, please post it here and I'll add it to the list. I don't mind if things are repeated... it means that I got it right
    If anyone thinks I should include anything else, please put your ideas here too..
    Thanks all
    Mike Ghia
    CODE BHP (OE) C:R Vehicle Fitment Year From Year To Cast / Forged Crank Head Port VVT Water pump Turbo Throttle ETKA REMARKS Injector size Piston Pin Notes
    ADR 125 A4 11/94-04/99 LARGE THEN SMALL NON THEN VVT NASP Large: 058 103 373 A, Small: 058 103 373 D
    ADR 125 A6 10/95-10/97 LARGE THEN SMALL NON THEN VVT NASP Large: 058 103 373 A, Small: 058 103 373 D
    ADR 125 AUDI CABRIO 04/97-08/00 LARGE THEN SMALL NON THEN VVT NASP Large: 058 103 373 A, Small: 058 103 373 D
    ADR 125 PASSAT 12/96-01/99 LARGE THEN SMALL NON THEN VVT NASP Large: 058 103 373 A, Small: 058 103 373 D
    AEB 150 9.5:1 A4 02-95 (EA 827 block) Dec-98 CAST LARGE NON VVT EXTERNAL K03 CABLE 20MM
    AEB 150 9.5:1 A4 04-95 (EA 827 block) Jul-98 CAST LARGE NON VVT EXTERNAL K03 CABLE GR 20MM
    AEB 150 9.5:1 A4 08-97 (EA 827 block) Jul-98 CAST LARGE NON VVT EXTERNAL K03 CABLE ZA 20MM
    AEB 150 9.5:1 A6 04-97 (EA 827 block) Jan-99 CAST LARGE NON VVT EXTERNAL K03 CABLE 20MM
    AEB 150 9.5:1 A6 04-97 (EA 827 block) Jul-98 CAST LARGE NON VVT EXTERNAL K03 CABLE GR 20MM
    AEB 150 9.5:1 PASSAT (6A block) Oct-96 Dec-98 CAST LARGE NON VVT EXTERNAL K03 CABLE 20MM
    AGU 150 9.5:1 A3 Dec-96 ?? FORGED LARGE NON VVT EXTERNAL K03 CABLE SMALL 20MM
    AGU 150 9.5:1 A3 Dec-96 Jul-98 FORGED LARGE NON VVT EXTERNAL K03 CABLE GR SMALL 20MM
    AGU 150 9.5:1 BORA Sep-00 ?? FORGED LARGE NON VVT EXTERNAL K03 CABLE SMALL 20MM
    AGU 150 9.5:1 BORA May-00 01-Apr FORGED LARGE NON VVT EXTERNAL K03 CABLE J SMALL 20MM
    AGU 150 9.5:1 GOLF Oct-97 ?? FORGED LARGE NON VVT EXTERNAL K03 CABLE SMALL 20MM
    AGU 150 9.5:1 GOLF Aug-98 01-Apr FORGED LARGE NON VVT EXTERNAL K03 CABLE J SMALL 20MM
    AJH 150 9.51 SHARAN Nov-97 Feb-00 K03 CABLE
    AJH 150 9.51 ALHAMBRA Nov-97 Feb-00 K03 CABLE
    AJL 180 9.5:1 A4 Aug-97 01-Sep LARGE KO3 CABLE
    AJL 180 9.5:1 A4 Oct-97 Jul-98 LARGE KO3 CABLE GR
    AJL 180 9.5:1 A6 Nov-97 Oct-00 LARGE KO3 CABLE
    AJL 180 9.5:1 A6 Nov-97 Jul-98 LARGE KO3 CABLE GR
    AMB 170 A4 01-Jul ?? J
    AMK 209 9.0:1 S3 Sep-00 02-Apr FORGED SMALL VVT INTERNAL KO4 DBW LARGE
    AMU 225 9.0:1 TT ?? ?? 20MM
    ANB 150 A4 May-99 Jun-00
    ANB 150 A6 Jan-99 ??
    ANB 150 PASSAT Jan-99 Aug-00
    APH 150 9.5:1 BEETLE Jan-99 Jun-00 NON VVT SMALL
    APP 180 9.5:1 A3 Jul-99 May-00 KO3 DBW
    APP 180 9.5:1 TT Sep-99 Sep-00 KO3 DBW
    APP 180 9.5:1 TT Sep-99 01-Oct KO3 DBW BR
    APU 150 9.5:1 A4 Aug-98 01-Sep
    APU 150 9.5:1 A4 Aug-98 Jul-99 ZA
    APU 150 9.5:1 A6 Nov-98 ??
    APU 150 9.5:1 PASSAT Jan-99 Aug-00
    APX 225 9.0:1 TT Oct-98 ?? FORGED NON VVT INTERNAL KO4 DBW LARGE 20MM
    APY 209 9.0:1 S3 Nov-98 Aug-00 NON VVT KO4 DBW LARGE
    AQA 150 A3 Aug-98 01-Apr
    AQJ 180 9.5:1 A3 Nov-98 Aug-00 NON VVT INTERNAL KO3 DBW 20MM
    AQJ 180 9.5:1 TT Oct-98 Aug-00 NON VVT INTERNAL KO3 DBW 20MM
    AQX 150 9.5:1 IBIZA CUPRA 1999 2001 SMALL KO3 DBW D4 std
    ARK 150 A4 Jul-98 Jul-99
    ARK 150 A6 Jan-99 May-99
    ARX 150 9.5:1 A3 Sep-00 ?? SMALL VVT KO3S DBW LARGE
    ARX 150 9.5:1 BORA Sep-00 01-Apr SMALL VVT KO3S DBW LARGE
    ARY 180 9.5:1 A3 Sep-00 ??-05 NON VVT KO3S DBW LARGE 19MM
    ARY 180 9.5:1 TT Sep-00 ??-05 NON VVT KO3S DBW LARGE 19MM
    ARZ 150 9.5:1 A3 Sep-00 ?? 20MM
    ARZ 150 9.5:1 GOLF Sep-00 ?? 20MM
    ATC
    ATW 150 A4 Jan-00 ?? NON VVT KO3 DBW
    ATW 150 PASSAT Jan-00 ?? NON VVT KO3 DBW
    AUG 180 GOLF ?? ??
    AUM 150 9.5:1 A3 May-00 ?? SMALL VVT INTERNAL KO3S DBW LARGE 19MM
    AUM 150 9.5:1 TT 01-Jan ?? SMALL VVT INTERNAL KO3S DBW LARGE 19MM
    AUM 150 9.5:1 BORA Sep-00 ?? SMALL VVT INTERNAL KO3S DBW LARGE 19MM
    AUM 150 9.5:1 GOLF Sep-00 ?? SMALL VVT INTERNAL KO3S DBW LARGE 19MM
    AUQ 180 9.5:1 A3 May-00 ??-05 VVT KO3S DBW LARGE 19MM
    AUQ 180 9.5:1 TT Aug-00 ??-05 VVT KO3S DBW LARGE 19MM
    AUQ 180 9.5:! BORA 02-May ??-05 VVT KO3S DBW LARGE 19MM
    AUQ 180 9.5:1 GOLF 01-Jun ??-05 VVT KO3S DBW LARGE 19MM
    AVC 150 9.5:1 BEETLE Jul-99 Oct-00
    AVJ 150 9.5:1 A4 Dec-00 ??
    AWC 150 9.5:1 SHARAN Apr-00 ??
    AWD 150 9.5:1 JETTA May-99 ?? NON VVT LARGE 20MM
    AWL
    AWM 170 PASSAT 01-Feb 02-Apr INTERNAL MEX
    AWM 170 PASSAT 02-May ?? INTERNAL MEX V6
    AWP 180 9.5:1 JETTA 01-Jun ?? VVT KO3S
    AWP 180 9.5:1 BEETLE 01-Nov ?? SMALL VVT INTERNAL KO3S DBW LARGE
    AWT 150 9.5:1 A4 Jun-00 01-Sep VVT KO3 DBW SMALL
    AWT 150 9.5:1 A6 May-00 ?? VVT KO3 DBW SMALL
    AWT 150 9.5:1 PASSAT Oct-00 ?? VVT KO3 DBW SMALL
    AWU 150 BEETLE Oct-00 ?? VVT KO3 DBW SMALL
    AWV 150 BEETLE Jun-00 01-May VVT KO3S DBW LARGE
    AWW 150 9.5:1 JETTA Jun-00 ?? VVT
    AYN
    AYP 150/180 9.5:1 IBIZA CUPRA 2001> ?? SMALL non-VVT INTERNAL KO3 DBW 20MM 9.5:1, emission spec EU2/EU3
    BAM 225 9.0:1 S3 01-Aug 02-May FORGED SMALL VVT INTERNAL KO4 DBW LARGE 20MM
    BAM 225 9.0:1 TT Sep-00 ?? FORGED SMALL VVT INTERNAL KO4 DBW LARGE 20MM
    BBU 180 9.5:1 IBIZA ??-05 ??-08 KO3S DBW
    BBU 180 9.5:1 POLO ??-05 ??-08 KO3S DBW
    BEK 180 JETTA 01-Jun ??
    BEX 190 9.5:1 A4 02-Nov ??-03 KO3S DBW
    BE 190 9.5:1 TT ??-05 ??-06 KO3S DBW
    BFB 163 9.5:1 A4 02-Apr ?? KO3S DBW
    BFV 240 9.0:1 TT - SPORT ??-05 ??-06 KO4 DBW
    BJX 150 9.5:1 IBIZA ??-04 ??-08 KO3S DBW
    BJX 150 9.5:1 POLO ??-04 ??-08 KO3S DBW
    BVP 163 9.5:1 TT ??-05 ??-06 KO3S DBW
    VER 150 SHARAN ?? ?? INTERNAL
    VER 150 BORA INTERNAL
    Updates will be highlighted in blue
    AGN = n/a 125PS internal water pump 058 103 373 X head on it.
    AGN has an 058 103 351 E head
    ARZ engine has an 06A 103 351 D head, so first 3 letters then match the 06A blocks.
    There are no big port 06As that we are aware of.
    AUM head is 06A 103 351 G
    AEB - head is 058 103 353 E (same head as AFY, again poss overseas engine)
    ADR & ABT (o/seas code?) - 058 103 351 G head, same as AGN (barring 06X bottom end), which are all n/a engines
    ARG (early) - 058 103 351 G head
    ARG (late, auto version) - 06A 103 351 D
    APU - 058 103 351 G head
    ANB - 06A 103 351 D, same as late ARG
    - 06A 103 351 D = aged
    Other threads:
    http://www.clubgti.com/forum/showthread.php?t=2708
    TBC code: Audi A4 8D facelift model: block went to 6A at this facelift.
    AGU to check if external or internal water pump
    cupracraig likes this.
  2. Phil
    Phil Forum Member
    Ont tinternet.
    Good Idea mate. Once it's finished we can put it in the FAQ's. I'll sticky this for now. :)
  3. Michael Ghia Forum Member
    Ok,
    Codes now up to 36.
    I have very little info on which engines have cast and forged cranks.
    Also need info on which engines have small port and large port heads.
    Also info on injector size, VVT or not, Internal/external water pump, Compression ratio, throttle cable/fly by wire and Turbo spec.
    MG
  4. Michael Ghia Forum Member
    This is how things look so far.
    Please let me know if I've got anything wrong.
    MG
    Edited by: Michael Ghia
  5. Michael Ghia Forum Member
    Someone one here must have more info on these engine codes?
    Thanks in advance
    Mike
  6. edc1 Forum Member
  7. Funkyfin2000 Forum Addict
    Stafford, United Kingdom
    wheres my copy Michael! :lol:
  8. Seizure Forum Member
    Northampton, UK
    AMK:
    C/R - 9.5:1
    VVT = Yes
    Water Pump = Internal
    Turbo = K04
    Throttle = FBW
    Injectors = Large
    APY:
    C/R - 9.5:1
    But saying that, I thought all K04 equipped engines had a 9.0:1 C/R, but that's what ELSA is telling me.
    I checked the AGU, AMK and BAM and all of them were 9.5:1 ?!?!?
    Edited by: Seizure
  9. Michael Ghia Forum Member
    Thanks all for the info,
    I'll be publishing the full sheet once its complete. Until that time, please save the spreadsheet above.
    Mike
  10. RO
    Ro Forum Member
    Cambridge
    mike... can you confirm that the AJQ code is deffo 180bhp??? i have this engine and thought it was only 150bhp??
    cheers
    Rowan
    Edited by: mouse
  11. RO
    Ro Forum Member
    Cambridge
    this is the turbo number from my AJQ and a picture of the engine, i'm not sure how much info you can get from these but here they are anyway.
    mou
  12. nutter4x4 Paid Member Paid Member
    Lao Peoples Dem. Rep.
    yeh AJQ is 180bhp i have one its from an a3 1.8t sport quattro, uses the ko3 sport turbo
  13. RO
    Ro Forum Member
    Cambridge
    woooooooooooo hoooooooooooooooooooo
    i just got 30bhp for free!!!!!
    Bonus!!!!
  14. Michael Ghia Forum Member
    Seizure,
    I will check up on the compression ratio's...
    Do you have any pics of your install?
    Chers
    MG
  15. Lee-GTi Forum Member
    There are two water pumps on the S3/and 225TT there is a small electric one that cooles the turbo down!
    you could also have info on what side the thottle body is on as some peep have no idea there are to type's mine is on the N/S hope this helps
  16. Michael Ghia Forum Member
    Thanks Lee, I'll look into the inlet manifold idea... it might help a lot of folk.
    Seizure,
    I've just crossed referenced the AMK pistons and head with the BAM and they are the same so I'm presuming that the compression ratio will also be the same at 9.0:1. Thanks for that.
    MG
  17. Michael Ghia Forum Member
    Mouse, thanks for the pics.
    MG
  18. Chris H Forum Junkie
    How's the spreadsheet coming Michael? :)
  19. Michael Ghia Forum Member
    Chris,
    I have just yesterday installed ETOS on my computer (Skoda, Seat, Audi, VW) parts program on my computer so along with Ekta I should be able to get the other pieces of information I need to complete the spreadsheet... or close to anyway :)
    I'll have an update in the next couple of days and will post it up here.
    MG
  20. Michael Ghia Forum Member
    Here's the latest list. I have had a quick look at Etos and it'll take a while to get used to. Its very different to Etka!
    MG
