Help!! Wife has a GTi Cab Mk1 and this morning the immobiliser would not turn off. Found control box and it says- Cobra 0802T 4C0802STF TPDP4009 on the box. Anyone any idea what might be wrong and how do I kill the bloody thing so I can start the engine.
if you want to remove it completly can you get to all the wires that are connected. they normaly cut into 3 points. ignition (black wire), fule pump (yellow/red wire) and starter (red and black) the imobelisers are normaly connected to the wiring by the ignition switch or fuse box. if your stuck let me know.
Just been out to have a look at it. On the dash the LED/switch has red, blue and 2 black but I assume that won't help as I disconnected this from the control unit to no avail. On the control unit (behind dash) there is the cable from the LED thingy and a whole bunch of black wires disappearing into the engine bay. Also it has two dip switches on there. Looks like I will have to go to a specialist which sounds expensive. [:^(]
where are you? i could remove it for you. All you realy need to do if find where the black wires connect to. these should connect to the wires i mentioned before and the you rejoin them.
