VR6 OBD1/ OBD2?
Discussion in 'VR5, VR6 & Wx' started by xplosiv, Nov 20, 2004.
  1. xplosiv New Member
    Am looking to buy a Vr6, but have seen some vr engines described as OBD1 and some as OBD2. Was wondering what the difference was??
  2. b'locks Forum Addict
    Revised engine management
    '92-'95 = OBD1
    '95-'97 = OBD2
    Edited by: b'locks
  3. MrBen Forum Junkie
    Amongst other differences, the OBD2 tend to be more powerful as stock, despite VW quoting the same power figure (174bhp).
  4. binliner Forum Member
    Other things were changed at the same time as the engine management
    so generally OBD2 cars will have 288mm brakes instead of 280mm,
    different throttle body and cosmetic differences (early VR6s had the same
    textured arches, side stips & bumpers as the gti... later ones didnt)
  5. AndrewF Forum Addict
    Milton Keynes
    nah, the obd2 being more powerful is a myth... the vr6 owners club's rolling road days have proved this. a healthy obd1 could be more powerful than a healthy obd2. all depends on the individual car, worth noting that every single vr6 tested was higher than 174bhp!
    they added a few other updates along with uprated management, such as different side repeaters, bigger brakes, they lost the arches, added fully colour coded bumpers. only other engine difference i can think of is that they reduced the top timing chain to singel row (obd1 are double row, but eat the top tensioner runner).
    for vr6 info visit vr6oc.com
  6. Jeff Forum Junkie
    London
    theres no distributor on the later ones they have coilpacks instead.
  7. xplosiv New Member
    Thanks for the quick reply guys.has anyone owned a obd1 and obd2, is there any performance difference? also when u say
    92-95 obd1
    95-97 obd2
    anything up to a 95 plate is obd1 and everything 95 plated and onwards is obd2 correct??
  8. binliner Forum Member
    M plate and before is usually OBD1, N plate and after is usually OBD2 (I
    say usually because with VW theres always a few oddities!)
    The distributor thing isnt an OBD1/2 thing... I think coilpacks were
    introduced around 93/94
  9. xplosiv New Member
    so the obd1 and obd2 changes took place across the vr6 range. ie will the same dates will apply to vento and corrado VRs??
    Edited by: xplosiv
  10. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Corrado never had obd2
  11. AndrewF Forum Addict
    Milton Keynes
    yeah, didn't the corrado stop being made in '95?
    the obd switch is across the whole vw range i think. certainly all mkIII's.
  12. PDA
    PDA Forum Member
    So all 2.9's are obd1
  13. AndrewF Forum Addict
    Milton Keynes
    oh, yeah, and early obd1's had a distributer, later had coilpack (on golf's it only '92 and very very early '93 cars that had dizzy, my '93 is coilpack)
  14. xplosiv New Member
    thanks for the advice guys certainly been very helpful.
  15. b'locks Forum Addict
    Correct...this has been proven beyond doubt by various Rolling Road days.
  16. ozdub New Member
    Obd1 & obd2 vr6 powr info Help??
    Hi, Can someone confirm if there a power difference between the vr6 OBD1 set up & the OBD2 set up? I have heard things that one has more bhp than the other? is this true? Chrz
  17. Supercharged Forum Member
    BHP is the same although OBD2 cars always seem slightly more responsive due the the better management. The Corrado 2.9 lump and MK3 Highlines obviously got slightly higher figures but any VR engine can be brought up to 200+ Bhp fairly easily by just de-restricting the air intake, VSR / Shrick Manifold and Cams can shift it to 220BHP with more low down torque.
    The main difference is MPG, with OBD1 one you get between 30-35 on a good day but with OBD2 you can achieve 35-38MPG - pretty good going for an engine of nearly 3 Litres!
  18. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Read the post immediately prior to yours... ;)
  19. neil kaye Forum Junkie
    england
    obd,stands for on board diagnostics does it not? so how is that related to power,surely its just a difference in diag between the two management systems,not well up on v.r's so im just asking out of interest
    my two mates (who are brothers) have v.r's.one has obd1 and the other has an obd2,theyve both drove each others and said theres no evidential difference,they feel the same
  20. Toyotec
    You are correct.
    OBD relates to emissions monitoring.
    OBD1 is the US EPA emissions monitoring std which ran to 94 then in 95 more parameters and calibration functions where included and this std became OBD2. OBD2 also runs of K line. For example all US/CDN MK3s or Corrados have a MILs, this was not a requirement for Euro vehicles as was 3 HEGO sensors, under floor catalysers and so on.
    In Europe most of the these functions relating to US OBD are switched off! But the remainder can still be accessed via a K line. The remainder does not make the vehicle "OBD2". Many of the european vehicles like Merc, BMW, VAG and Opel communicate with the same protocols after 95 hence the rise of handheld diagnostic readers. You many find though that generic US "OBD2" tools do not work on many european vehicles due to differences in data sets.
    In 95, Europe had EU1 emission stds and you find some of the hardware that benefitted US federal emission monitoring, fuel economy and emissions became std euipment on euro vehicles for our drive cycles.
    This OBD2 vs OBD1 nonsense is starting to creep into ABF 16v types too. See how myths are generated.
    There should be no drive difference (or small torque deltas) between a 93MY MK3 VR6 and a 96MY MK3 VR6.
    The later MK3 VR6 may have the abilty to adjust individual batches of injectors and coil towers to compensate for manifold tract differences over time bearing in mind that these engines are designed to run at stoich during the majority of load conditions except WOT and high rpm.
    Perhaps I need to run a test on two of these on the dyno to prove the OBD1/2thing is another imported myth.
