Changing ABF Cams - A retards guide?
Discussion in '16-valve' started by cforehead, Jan 13, 2005.
  1. cforehead Forum Member
    Barnstaple, North Devon
    Anyone got one? The engine's out, need to replace the current KR cams
    with the original ABF ones. Anyone know where there's a good 'How to'?
    The 8v one in the FAQ's is obviously of limited use..
    Cheers,
    Fordo!:thumbup:
  2. prof Forum Addict
    Suffragette City
    don't ABF cams are great, KR cams will offer no benefit
  3. cforehead Forum Member
    No, it came with Kr cams in... but I'm putting the ABF ones back in it!!!
    Fordo!
  4. prof Forum Addict
    Suffragette City
    ahhhhhhhhhhh is it on k-jet or ecu? as tubs found the abf cams did't quite line up with the k-jet dizzy,
  5. cforehead Forum Member
    Ecu (lifted straight from a 96 mk3)... easy job or no? When I say easy,
    I know it's not rocket science, but is it a paticularly 'involved' job,
    i.e am I gonna be up to my eyes in oily bits for 4 hours and get to
    work late?!
    Fordo![:D]
  6. prof Forum Addict
    Suffragette City
    yes :lol:
  7. prof Forum Addict
    Suffragette City
    GVK wrote this up i believe he's normally around about 12.30
  8. cforehead Forum Member
    Allrighty then! Cheers Prof, I'll PM him and see what he comes up with!
    Fordo!:thumbup:
  9. GVK
  10. cforehead Forum Member
    Nice one [​IMG]Will have a butchers hook!
    Cheers[:D]
    Fordo
  11. Tubthumped Forum Junkie
    Hebden Bridge
    Prof - it's the ABF head that doesn't line up with the K-Jet dizzy.
    All the camsets i've tried have been the same.
  12. Golden Forum Junkie
    Are you saying you can't fit the KR dizzy to the ABF head? [:s]
  13. Tubthumped Forum Junkie
    Hebden Bridge
    No, i'm saying the ABF head has the dizzy bolt holes drilled slightly too far around. This means i'm at the full extent of my dizzy adjustment just to get it to the standard 6 degrees. I probably have some more power to be gained by another degree or 2 of advance.
  14. Golden Forum Junkie
    Ahhh sorry mate I understand now :)
  15. Tubthumped Forum Junkie
    Hebden Bridge
    One day i will drill and tap the head in a more suitable location....
    Probably be the same day i re-fit my ABF cams...
  16. cforehead Forum Member
    EEEEK!!!! I've got to the point of removing both cams from the head... and I have come to an impass...
    Problem is that the exhaust cam has the belt pulley still attatched,
    and the cylinder head is shaped so as to 'fit into' the indentations on
    the back of the pulley. This means that when I try to lift out the cam,
    the pulley hits the head and won't budge. If I slide the cam along to
    try and lift the pulley over the bits on the head, one of the lobes
    hits the cam clamp threaded pin thing ([:$]) and won't let me pull it any further.
    Which leaves me with the only option of trying to remove the pulley with the cam still in the engine [:s][:s][:s]. I wasn't looking forward to doing that in a vice, let alone using the cylinder head as one!
    I'm using the guide for a 9a that GVK gave me, and I assume that the 9a
    head lets you remove it with the pulley still in place, whereas the ABF
    heads shape won't allow it.
    Anyone got any experience here, or should I just bight the bullet?
    Fordo![:^(]
  17. cforehead Forum Member
  18. smithy Forum Member
    Scotland
    Im pretty sure the ABF head will let you remove it 'in place' as well. Torque the camshaft back down, and get a wide flathead screwdriver or similar, put it through one of the spokes on the camshaft pulley and rest it on the side of the head. This will stop it shifting when you undo it. Now get a socket (think its 24mm) and a long extension and undo the sprocket bolt while you brace the screwdriver against the head. You might want to get someone else to hold the screwdriver while you undo the bolt. Easy :thumbup:
  19. cforehead Forum Member
    Good man:thumbup:. I did wonder about that, I
    was just worried about damaging the head where the gasket goes with the
    screw driver. I'll just have to cushion it with a bit of wood or
    something. I just wanted to know that I'm not having the problem
    because I've done something wrong.
    Cheers mate!:clap::clap::clap: Knew mr Bump would come to my rescue!
    Fordo!
  20. smithy Forum Member
    Scotland
    No problem... yeah, like you said, use a bit of plastic or something to cushion it, i've got away without marking the head using nothing before though. Im not sure if thats the correct way but its always worked for me :)
