THIS is a big 16v throttle body
Discussion in '16-valve' started by flusted, Jan 27, 2005.
  1. flusted Forum Member
    Kazakhstan
    This is the weber firebreather tb next to my flowed 16v jobbie.
  2. drunkenalan Paid Member Paid Member
    Leicester
    wtf r u going to do with that its huuuuuuuuugggeeee!
  3. vw_singh Events Team Paid Member
    Does it even fit on the standard manifold?
  4. drunkenalan Paid Member Paid Member
    Leicester
    its about the same size as my audi s2 engines throttle thats sitting on the floor at the mo
  5. Cleggstar Forum Member
    where did u find one of those? looks huuuge
  6. Tubthumped Forum Junkie
    Hebden Bridge
    You'll want this then....
    Edited by: Tubthumped
  7. flusted Forum Member
    Kazakhstan
    it comes with an adaptor plate to fit the standard manifold! Found a bit about em on the corado forum and apparently the company who made them only had 3 left and they all sold a few months back for near 200 each [8-}]
    I luckily found it on the pvw classifieds for 50.only prob is i need to mount the throttle switch for the isv [:s]
  8. Golden Forum Junkie
    Fitting large single TB to a 16V K Jet is about as good as an Eckotec Valve.
    There is no performance gain from fitting a bigger single TB, all it will do is bollox your MPG, throttle response and driving quality.
  9. prof Forum Addict
    Suffragette City
    the claims for that single TB are pretty impressive, i will reserve judgement until we see the stealthed results ;)
  10. Golden Forum Junkie
    I'd guess that TB has about 12% more area than the standard unit.
    I've said this over and over again, unless you've overbored an engine, dramatically improved VE at the upper end of the rpm or increased the working rpm range how can it need more air [:s]
    If you suggest that the original TB is restrictive ask yourself why VW would limit the performance of their own engine on what was their top of the range performance model [:s]
    Finally for the cynics, the twin flap design is far more costly to design and manufacture. In an industry where saving pence per car is seen as a gain, why do it?
  11. prof Forum Addict
    Suffragette City
    the manufactures of the big TB claimed 12% increase in power IIRC
    but as you say golden, i think it'll only make more power if the engine needs more air than the stock TB supplies
  12. martyn_16v Forum Junkie
    behind the sofa
    I agree that the TB is by no means the most restrictive part of the system, and that gains will be marginal, but...
    The answer to both questions is driveability. What do you think is going to sell more cars, an engine that makes 2-3 bhp more but is a shit to drive in traffic, or one the wife can use? ;) Some of the TB's i've got even have a wedge bolted to the smaller butterfly, presumably to smooth transition off idle even further
  13. GVK
    :lol: Agreed.
  14. Andy947 Forum Addict
    Scotland, Aberdeen
    But you are completely forgetting the simple fact that when people buy tuning stuff, if its bigger or looks better it MUST be better.....
    [8-}]
  15. flusted Forum Member
    Kazakhstan
    Ok well it looks cool,does that count?? :lol: There was dyno plots for this tb that came with them apperently proving a big hike in bhp but ive always been a sceptic.
    Il give it a go anyway and report back.
  16. Nurburgring Forum Member
    Edited by: Nurburgring
  17. Golden Forum Junkie
    Well that's that sorted, I'll go back to dribbling [:[]
  18. Nurburgring Forum Member
    Just answering some good points you made :). As i completly agree if this is the only modification you would not notice it. ;)
  19. Golden Forum Junkie
    Nope, its no good I cant leave it.
    Thank you for trying to teach me in laymans terms but I think Ill carry on considering VE to be the actual filling of a cylinder compared to the theoretical maximum filled volume at a given pressure.
    What the hell has VW theoretically limiting top end performance of a 16V got to do with book spec fuel economy? This week will be testing the new Golf 16V and seeing what the driving around foot to the floor MPG will be.
    Finally, do you even know what pumping losses are?
    Edited by: Golden
  20. KeithMac Forum Junkie
    Kazakhstan
    It`s the damp fart you get the morning after a vindaloo :lol:
