16v Carbs front water pipe dont fit
Discussion in 'Throttle bodies & non-OEM ECUs' started by altern8, Feb 13, 2005.
  1. altern8 Forum Junkie
    Cocos (Keeling) Islands
    what did you guys do with the front water pipe on the 16v it seems to stop the linkage moving on a set of 45 dellotos [:$]
  2. GVK
    You need a metal water top pipe connection off an early Valver Alt , cut and shut to suit ;)
  3. mk1. Forum Junkie
    yep as said,cut it and get it alloy welded to suit,make sure you have a decent uncorroded one as they weld better
  4. altern8 Forum Junkie
    great stuff cheers guys :)
