Is there a windage tray that fits a 16v
Discussion in '16-valve' started by GVK, Jan 8, 2004.
  1. GVK
    The diesels have a windage tray to stop oil surge incorporated into the sump gasket, does this fit a 16v block?
    If not who sells them for 16vs?
    Edited by: G_V_K
  2. PhatVR6 Forum Junkie
    Is GVK planning to runs slicks? [:D]
  3. GVK
    We're going to Mallory next month Paul, it has the longest corner in the UK (Gerrads) Ian Carvell was saying that a number of engines fail from oil surge around there.
    Of course If I ever get some A048s the greater lateral grip will make the problem worse.
  4. PhatVR6 Forum Junkie
    Just put a bit more oil in it! any excess will burn off.
  5. harry_the_cake Forum Junkie
    Antarctica
    I thought a windage tray was more to stop power loss from the crank whipping up the oil and baffles were for oil surge?
    The 16v has plastic baffles as standard (but you knew that). The diesel tray does fit the 16v, unless you have a longer throw crank.
    Edited by: harry_the_cake
  6. bigfatpixey Forum Member
    Vietnam
  7. alby Forum Junkie
    Albania
    autocavan used to do them.you could try volkspeed as they do all the old volksport stuff.
    45 quid here
    Edited by: alby
  8. prof Forum Addict
    Suffragette City
    dont think the deisel tray and the baffles fit together, and over filling it can cause airation of the oil-lots of bubbles in it which is equally bad for your bearings,
    sorry thats not much help
    Edited by: prof
  9. PhatVR6 Forum Junkie
    GVK, you got a PM....
  10. dUff
    dUff Administrator Admin
    I bought mine from TSR but its actually a VW part that is the gasket also so likley its the same part, i may be able to dig out the number for you as i have a photo of it somewhere
    I am using a TSR baffled sump and 8v spreader/baffle and VW windage plate in mine, TSR sumps are crap as you have to grind of metal to get them to fit past the old pump and the paint comes off and blocks your strainer , which was all very nice [xx(]
    Edited by: dUff
  11. GVK
    So that daft plastic thing which clips to the oil pick up has to be removed for the windage tray to fit?
  12. Rallye Forum Junkie
    dry sump? :lol:
  13. dUff
    Yeah fit a 8v spreader/baffle as that much smaller that the 16v item baffle
    Anyway for coners the baffled sump is what you need, the windage plate is really for braking and acceration i always thought
    Edited by: dUff
  14. GVK
    Thhinking about it, the windage tray won't help oil surge during cornering, as HTC said above [:s]
    There's a Schrick alloy baffled sump on Ebay - pity it's in the states tho.
  15. dUff
    Make you own baffled sump its only a few plates welded into a normal sump
  16. evozippy Forum Member
    My Corrado g60 had a sort of windage tray that clips onto the oil pump pickup which also had baffles on it. Its was a standard item that vw put on them(i think) from memory its something like 25x20cm in size
  17. evozippy Forum Member
    You need a baffled sump anyway as the windage tray is to keep the crank from whisking the oil and creating air bubbles, thats where the name "windage tray" came from.
  18. Andy947 Forum Addict
    Scotland, Aberdeen
    I remember seeing a linki to where someone had made their own baffled sumpwith a hinged part that allows flow one way, but stops it another - why not make one?
  19. Golden Forum Junkie
    Gary have you ever actually had oil surge on yours?
    I've never got it, and although not the best looking item I think the clip on combined baffle/windage plate that comes standard should do a half reasonable job.
  20. DEX
    Dex Paid Member Paid Member
    so are we suggesting that the std 16v *baffled sump* might well be up to the job?
    GVK has me panicking now!
