race/road spec 2lt 16v on throttle bodies
Discussion in '16-valve' started by C-N-M, Mar 10, 2005.
  1. C-N-M New Member
    well just doing a little forum research into this what would i need to do to a 2ltr 16v to get 220-240hp on throttle bodies i have quite a few abf,9a and 6a engine knocking around just wanted some good interested comments
    and no i don't want 20vt boring nothing like good n/a engine for me now[:D]
    thanks
    this is next option if my first option full through[:^(]
  2. chrismc Forum Junkie
    Lightened/Balanced preferably steel 9A bottom end..(looking at 8000+rpm)
    Flowed head
    Schrick 276s minimum
    ITBs
    4 branch
    Aftermarket management
    Suitable exhaust
    Very Deep Pockets ;)
  3. GVK
  4. C-N-M New Member
    chris mate my budget for the engine is min-4,500-8,000 max on engine spoke to many companies jd engineering wanted around 9k for 16vg60 grant motorsport can build me one i have heard malcolm ring is selling his 16valver itb engine through a mate so anything possiable
    but want something different than 20vt as it common as muck so gone back to n/a power that why i asked about mad20v engine[:D]
  5. ianb Forum Member
    I think you'll be looking at a minimum of steel internals a knife edged custom light weight crank custom rods pistons a Schrick solid lifter head in combination with 304+ cams (Schricks)running to 8.5-9k
    oh and TB'S independant mapping
    and much more
    Ian
  6. RobT
    RobT Forum Junkie
    Cheshire
    Hi
    IMO the main problem you are going to find is someone reliable who
    knows VW 16V's to build it for you - most of the bits are available
    relatively easily - but what bits to use.....
    The power you want is definately achievable with your budget and if you
    do this, I would have staged payments and the builder dont get most of
    the cash until you have dyno sheets to prove power / torque (and at this
    kind of money you should be able to dictate what shape of power curve
    you want (ish))
    You are right on the edge of needing a steel crank or not - a stock forged
    crank is good for 8600rpm if in good condition and balance checked -
    1200 extra if you need a steel one. A1 quality block - if any doubt at all,
    get a new one.
    Steel rods - loads of possibilities (arrow, eurospec, puter, carillo etc)- get
    some fairly light ones as some of them are for turbo engines are are
    much more than you will need
    Pistons - a compression hike would be useful - forged would be nice -
    loads of vendors (je, ross, accralite, wiseco etc). May need pockets for hot
    cams. If your not racing and capacity limited, 83.5mm gives a useful
    capacity hike.
    Fasteners and bearings - highest quality available throughout - arp bolts
    are good as are genuine VAG bearings
    Head - now then, big skill time - gas flowed (but how) maybe with bigger
    valves (valves from who and how much bigger). Solid lifter conversion
    (solid lifters from several vendors, arrow, schrick etc), machining for high
    lift cams may be needed
    Cams - lots of options - schrick are good but so are cat and newman -
    going to need a pretty wild set but this is where the skill and experience
    of the engine builder comes in, matching the cam spec to compression,
    porting, valve sizes etc - its the overall package that has to work in
    combination
    Ancillaries - a good oil pump / baffled sump / windage plate or dry sump
    Induction - TB's - various designs and sizes, you are going to need 45's
    as a minium, the bore dictates the type of power in combination with the
    other engine parts
    ECU - loads of options again, pick one where there is local experience to
    you as you will need a few remaps to get everything right
    Getting 240bhp out of a VW 16V isn't easy - but very doable.
    Your alternative to finding a builder, buying bits and hoping it all works is
    to buy an off the shelf engine, with dyno sheets to prove power. There are
    a few guys in europe where you can do this - and if your really serious,
    for 8K I'll get you one.
    Rob
    Edited by: RobT
