2.0 16v timing question
Discussion in '16-valve' started by mr.brown, May 10, 2005.
  1. mr.brown
    Sunny Surrey
    OK, so today's job was KR head onto 6A block. All went swimmingly until I fitted the clutch & flywheel. Twas at that point I realised I'd moved the crankshaft about a bit and as I hadn;t fitted the pulley I didn't have a clue what position the pistons were in.
    The head is fine, I haven;t fiddled with it and the inner and outer cam sprocket marks align where they should.
    The engine is in the shed with no gearbox so I have nothing to align the flywheel notch with.
    Is my only option now the screwdriver down no.1 spark plug hole jobbie?
    And it looks like the crank pulley had four holes for the notch so can be fitted in any position - is that right? [:s]
    Cheers.
  2. Seraph Banned
    -5129' 57N-07 29W
    the whole screwdriver thing is abit philistine like!
    Can you borrow a dti guage and use that?
    Should be a key on the crank pulley to align for one place?
  3. mr.brown
    Sunny Surrey
    Sorry, when I said notch I meant the raised bit on the crankshaft sprocket - is that what you mean by "key".
    On the reverse of the crank pulley there are four indents so that the raised bit/key can be fitted in any position - i.e. it don;t help none.
    BTW, What's a dti gauge?
  4. GVK
    Sean, you'll find that the crank pulley will only go on, and all the 4x 6mm allen bolts will only line up/screw in, in one place.
    I use the screwdriver on top of no.1 position method as did Vince @ Stealth when checking my cam timing.
    DTI (dial,test,indicator) is a special gauge fitted with a plunger that shows movement in parts on an analogue scale. [:-B]
  5. greg s Forum Member
    As I said to someone on here last night, the screwdriver/knitting needle
    approach sounds inaccurate but you can't be half a tooth out on the cam
    belt so as long as you pay attention you should get it bang on or 1 tooth
    either way, which you'll notice. The poor man's dial gauge is accurate
    enough for this job.
  6. mr.brown
    Sunny Surrey
    Cheers chaps.
    One last question, does the position of the intermediate shaft matter?
  7. martyn_16v Forum Junkie
    behind the sofa
    as gvk says, crank pulley will only go on one way
  8. martyn_16v Forum Junkie
    behind the sofa
    not on the 16v, no
  9. GTI
    GTI Forum Member
    Shropshire
    the intermediate shaft only runs the oil pump, so no it doesn't matter. (edit: beaten to it!)
    i timed mine with a screwdriver and you really can get it spot on.
    the difficult bit is getting the cam belt on and tightened without it slipping half a tooth. make sure you double check your alignments once its all back together and tightend up.
    Edited by: GTI
  10. GVK
    I put the crank one tooth out so, that when I tighten the belt it puts the crank 'on time'. Obviously check it all after turning the engine over one complete turn.
  11. greg s Forum Member
  12. GTI
    GTI Forum Member
    Shropshire
    exactly.
    "[:[]" my arse!
    Edited by: GTI
  13. greg s Forum Member
    :lol:
    I wasn't arguing that it's hard to keep it all timed up as you tension it.
    Edited by: greg s
  14. GVK
    tm altern8
  15. mr.brown
    Sunny Surrey
    Nah, only been 6 months since this died.....
