ABF into mk1 16v (KR)
Discussion in '16-valve' started by I V - mk1 16v, May 16, 2005.
  1. I V - mk1 16v Forum Member
    Queensland, Australia
    If i had an ABF that i wanted to put in my mk1 could i just swap over the 2 engines (block & head together) and just keep the KR K-jet injection and ECU/wiring etc.?? [:s]
  2. Oplaii Forum Member
    Jamaica
    The 'ABF' is a tall block is it not? theirs a few issues getting it to fit, but they do go in mk1's.
    Should be fine on kjet.
    Edited by: Oplaii
  3. iguana Forum Member
    Samoa
    Nooooooo, I can't keep up with that old 1.8 in it, so you cant go 2.0l! ;)
  4. GVK
    VICK on here has a full ABF on the Digi in his mk1, so the unit 'fits'... can't see any reason other than the exhaust manifold might foul the bulkhead, why it won't fit.
  5. Brookster
    M1 J40
    a bit like this then ;) [​IMG]
    ABF c/w K-Jet
  6. chrismc Forum Junkie
    seconded ;)
