I have 'found' a PDF copy of the 2e2 section of the Haynes carb manual on the E-Donkey network, the link click me if you have edonkey/emule. It will be very slow at the moment because only 1 person has the whole file at the moment, I've heard he is currently connected to the Razorback 2 server Edit, Emule Installation instructions: Download & install EMule, then paste this into 'Update server.met from URL' on the server tab: http://www.edk-files.com/x1/server.met and press update. This will give you a mahoosive list of emule servers, then sort the list by 'Users' or 'Files' which normally gives you the server 'Razorback 2' at the top. Double click it to connect, and while you're here right click and set its priority to 'High'. Edited by: rubjonny
Well if anyone would be so kind as to PM this file or a normal link to me, then I would be very grateful
